Old 12-13-2022, 05:16 PM   #1
jonho
Drives: 2013 FRS
2013 FRS timing issue
So I had an engine rebuilt for the 2013 FRS and at the same time I ordered new cam gears and timing chain. The issue I am having is now both sets of gears they have sent look wrong. My ones I had used a tab on the timing plate and the ones the have sent both times use a notch on the timing plate. With the new ones car does not start. I have included a picture the top one is original bottom is new. I am guessing with the new maybe I need new sensors or ECU flash?
jonho is offline   Reply With Quote
Old 12-13-2022, 06:49 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
13'-16' Same
17'+ Different.
Looks like you got a 17'+. Cam position sensor can't read it. I dunno if the pre facelift ECU can read the 17'+ cam position sensors. I know for a fact it can't read the 17'+ crank position sensor. Same issue, in'y vs out'y.
Old 12-13-2022, 07:03 PM   #3
jonho
Drives: 2013 FRS
Whats odd is the car ran fine before it had a ring land failure. So if it has a 17+ gear and 17+ sensor would that really work? Also I think it show same part for 13+ on cam sensor with subaru
Old 12-13-2022, 07:39 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't believe it will, but I can't say for sure 100% since I haven't tried it/seen it attempted. It's weird, but it does show the cam position sensor the same up to 17' even though it shows the cam gears are not. The waveform of the signal is going to be different so I am assuming it isn't going to work.
Thoughts @Ultramaroon
Cam sensor
https://parts.subaru.com/p/Subaru_20...2056AA270.html
Cam Sproket
https://parts.subaru.com/p/Subaru_20...3320AA021.html
Old 12-13-2022, 07:50 PM   #5
jonho
Drives: 2013 FRS
I should also add we have tried ROM B01C it originally had A01C.
Old 12-13-2022, 07:52 PM   #6
jonho
Drives: 2013 FRS
also found another cam sensor that says it fits. I wonder if one matches each type of gear.
https://parts.subaru.com/p/subaru_20...2056AA210.html
Old 12-13-2022, 07:56 PM   #7
Grady
Grady's Avatar
It will not work. It is not the sensors it is the ECU programming that is different.
The Following User Says Thank You to Grady For This Useful Post:
NoHaveMSG (12-13-2022)
Old 12-13-2022, 07:58 PM   #8
jonho
Drives: 2013 FRS
ok so how do I order the one with tabs just order 17+ gears? Why would my 13 have 17+ and 17+ programming? Since owning the car have added a turbo and the tuner used ecutek and didnt say the ECU looked different than any other 13.
Old 12-13-2022, 08:31 PM   #9
Did you buy it used? Signs point to updated engine+ECU. Have you checked the serial numbers?
Pre-facelift triggered on the negative-going edge of the waveforms. They changed the polarity because the sensors are less finicky about detecting tabs than the notches. Scroll down to about the middle of these pages.
Pre-facelift
Post-facelift
Old 12-13-2022, 08:41 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It wouldn't just be 17+ programming though, it would have to be the 17+ ECU as well as the tunes are not compatible and the pre facelift ECU can't read some of the newer sensors. Weird, I didn't think you could do the facelift ECU in a pre facelift car without creating all kinds of issues with the immobilizer.
Old 12-13-2022, 08:46 PM   #11
jonho
Drives: 2013 FRS
Yes bought it used. What I struggle with is that when my tuner tuned it ECU Version is ZA1JA01C and it ran fine no issues. We do a rebuild order the gears and they are the notched ones get no start. We tried to flash with ZA1JB01C no change. If it had updated engine ecu would it not show a 2017 ECU version? can you change the trigger without changing the whole ECU version?
Old 12-13-2022, 08:52 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No, that is what is so confusing here. 13-16' ECU shouldn't be able to read 17+ cam sensor or crank position sensor. But ZA1JA01C is original FRS rom calid.
Old 12-13-2022, 08:53 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Some of the other guys that know more may chime in later. I am lost on this one.
Old 12-13-2022, 10:04 PM   #14
jonho
Drives: 2013 FRS
yeah we are all lost on this one. I would get if it had some custom flash but the tuner starts with a fresh flash.
Timing Chain cover revisions / changes 2013-2020 FrickingReallySlow Engine, Exhaust, Transmission 0 09-21-2021 06:10 PM
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) MJones_RB Issues | Warranty | Recalls / TSB 9 08-22-2019 05:00 PM
Cam position - timing issue. cab33 Engine, Exhaust, Transmission 3 07-01-2018 12:52 PM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-11-2016 12:25 AM
FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! CSG Mike Tracking / Autocross / HPDE / Drifting 47 06-24-2013 06:23 PM
