Drives: 2017 Toyota 86 (Raven)
Is my 86 healthy??
I looked at my diagnostics with the OFT v2 tablet and wanted to know if everything’s running fine. I had it parked and idling while I ran the diagnosis. But as far as under the hood goes I’ve only added JDL UEL headers, a GrimmSpeed CAI and the Remark x FT Speed Quad Catback exhaust. I’ve had the tune on for some time. And I do my regular oil changes every 3-5k miles.
#2 |
Drives: frs
Better do a Compression Test and Blackstone Lab oil analysis.
| The Following 4 Users Say Thank You to Teseo For This Useful Post: |
#3 |
#4 |
You don't see it? I see it.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#5 |
Drives: 2013 FRS
From what I can see, none of those things on the OFT indicate there's a problem.
I think the better question, is why are you asking if it's healthy? Is it characteristically doing something wrong? CEL? Running rough? Weird sounds? If not, a compression test and oil analysis will tell you more.
#6 |
OP, Teseo's just yanking your chain.
![]() While driving, glance at your long-term fuel trim and knock correction for the most important indicators. LTFT should be within +/- 5% -ish. Shouldn't have any knock correction. Looks golden at idle.
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | blakkoutdarko (12-08-2022), humfrz (12-05-2022), Spuds (12-05-2022), Teseo (12-05-2022), x808drifter (12-06-2022) |
#7 |
#8 |
I see a smoothly idling engine.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blakkoutdarko (12-05-2022), humfrz (12-05-2022) |
#9 |
Pavement Grey
| The Following 3 Users Say Thank You to Sasquachulator For This Useful Post: |
#10 |
The Dictater
Drives: '13 Red Scion FRS
Uhh... Advance multiplier is 0. That seems bad. You normally want that at 1. (Edit, unless the tune has IAM set to 0, but that seems odd for an OFT tune)
OP, take a log and post it to datazap or something. Screenshots don't actually tell anyone much of anything. Also an oil analysis will tell you how the hardware inside the engine is doing. Edit:. Wow, how'd you screenshot stft at 0? That's normally all over the place.
Also: "Build Thread" |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | blakkoutdarko (12-08-2022), Ultramaroon (12-05-2022) |
#11 | |
Drives: Crapcan
IAM at 0 is weird. I almost think there is an issue with the OFT reading correctly. Possibly need to unplug and reconnect the OFT and the cable into the OBD2 and check again. If it was actually at 0 on IAM it would feel really really sluggish.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#12 | |
The Dictater
https://www.ft86club.com/forums/showthread.php?t=126500 I even knew about that at one point...
| The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (12-07-2022) |
#13 | |
#14 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"Now cough ...
Again ... "
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | soundman98 (12-07-2022) |
| Is this a healthy log? D00C | cookiesowns | Software Tuning | 3 | 08-26-2014 05:39 AM |
| Is she healthy, log. OFT | v86 | Software Tuning | 7 | 08-18-2014 09:29 PM |
| ◙◙◙ The "Keep Your Car Running Healthy" Thread | Real Auto Dynamics ◙◙◙ | Kevin@RAD | Announcements, Contests, Giveaways | 36 | 06-07-2013 03:26 PM |
