vroooooooom
Drives: 86
Final drive higher or lower for auto turbo?
Hi everyone. I'm thinking of swapping my final drive to acheive a higher top speed in my 86. I am boosted 300whp in my auto 86 but 5th gear is still useless. My question is will going for a higher final drive (4.556) be more beneficial than a 3.9 fd if the only goal is to make 5th gear usable.
#2 |
Drives: brz 2017 hksv2
what you mean with useless.? you find it too short now? with 4.56 will become even shorter, with 3.9 longer
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | NoHaveMSG (11-30-2022), x808drifter (12-01-2022) |
#3 |
30 minute maintenance
Drives: My18 wrxsti
4.56 fd will be slower top speed. If you want more top speed you need to go a lower number than 3.9 fd. ie 2.9 direction.
#4 | |
Drives: 2018 Subaru BRZ Limited with PP
https://www.blocklayer.com/rpm-gear On a stock car, here's following top speeds on 5th gear based on your FD. 4.6 FD: 118 4.3 FD: 126 4.1 FD: 132 3.9 FD: 139 3.7 FD: 146 Technically, your 5th gear should be the least of your worry. How often are you in the 100-146 mph range that your 5th gear will mean that much to you? Usually people complain more about the lower gears, as with more power, you are going through the gears quicker, making 1st and 2nd gears more "useless" as you say. So lowering your FD to something like 3.7 will give you more time in each gear and help reduce tire spin as well. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | Lucky21 (11-30-2022) |
#5 | |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | Dzmitry (12-01-2022) |
#6 |
vroooooooom
Drives: 86
The automatic gear ratios make 5th gear useless because it is almost like 6th gear in the manual. My question was if the short final drive can make 5th gear useable or should I just go with 3.9 final drive so my 4th will reach a better speed.
#7 |
vroooooooom
Drives: 86
![]() for reference this is what i'm talking about. 5th Gear in automatic is practically useless at 4.1 fd |
#8 | |
vroooooooom
Drives: 86
#9 | |
Drives: Crapcan
Example: I find 1st and 6th useless on track though the gear spacing is fine for all the other gears. All gears I find useful on the street.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (12-01-2022) |
#10 | |
So if I understand your question correctly, a higher FD like I mentioned in your AT will make 5th gear more "useable" as it will have more torque. EDIT: Disregard my conclusion. You want a higher top speed in 5th based on your OP, then you want a lower FD. Last edited by Dzmitry; 12-01-2022 at 10:58 AM. |
#11 | |
vroooooooom
Drives: 86
I know most people here don't really care about top speed but I was just genuinely curious if you could adjust that as I live in an area where such speeds are achievable legally (for the most part) Hope my post doesn't confuse others sorry. |
#12 | |
vroooooooom
Drives: 86
#13 |
then would be stupid to put like 3.9 finaldrive in your car. You 'd want 4.56 or sth higher in number, as you wouldn t have the torque necessary for enjoying the car
#14 |
Drives: My18 wrxsti
I think 300 hp is nice Regardless of FDR
| The Following User Says Thank You to gen3v8 For This Useful Post: | tomm.brz (12-02-2022) |
| Higher final drive ratio and increased engine braking | Purist | Engine, Exhaust, Transmission | 11 | 06-16-2019 12:25 AM |
| 4.556 Final Drive with a Turbo Setup | Sh1FTy | Forced Induction | 9 | 04-19-2018 06:13 PM |
| Final Drive Gearing, Auto vs Manual | KoolBRZ | Engine, Exhaust, Transmission | 9 | 09-11-2017 09:50 PM |
| 4.56 final drive with 6th gear from an auto?? | fr-s6MT | Engine, Exhaust, Transmission | 3 | 12-17-2016 11:47 AM |
| Any interest in 4.5 final drive from Auto Factory? | mike_ekim1024 | Engine, Exhaust, Transmission | 12 | 09-12-2013 08:41 PM |
