Old 11-14-2022, 10:18 AM   #449
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
sounds almost oem! how loud is it though, compared to oem? hard to tell
A bit louder than stock at WOT inside the cabin but not by much. Seat seats up it's basically stock sounding. Seats down there is some added resonance.
The Following User Says Thank You to RToyo86 For This Useful Post:
StraightOuttaCanadaEh (11-14-2022)
Old 11-26-2022, 10:20 PM   #450
IvoryHammer
Drives: '17 BRZ PP
Has anyone had any fitment issues to the front fan shroud/latch support? I'm having a tough time installing my header because it's rubbing up against it.
https://imgur.com/a/BPNTS8d
IvoryHammer is offline   Reply With Quote
Old 11-26-2022, 11:39 PM   #451
PulsarBeeerz
Drives: JRSC BRZ SOLD
With a wrapped header I have maybe 1/4” of clearance in that area. It was tight with the HKS EL as well.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
IvoryHammer (11-27-2022)
Old 11-27-2022, 01:01 AM   #452
RToyo86
RToyo86's Avatar
https://postimg.cc/5jMDrxzX
https://postimg.cc/H82wZ0y9
https://imgur.com/2VTFepP
https://imgur.com/BiEcyTV
Fitment was close as mentioned above while installing mine. The header to block flange holes allowed a bit of wiggling up/down to get everything set. I did hammer the belly pan as posts earlier showinf it could rub.
I am also realizing I don't think I got the titanium color thermal coating I ordered .
Looks darker than titanium and lighter than tungsten.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
IvoryHammer (11-27-2022), SCFD (12-07-2022), Teseo (11-27-2022)
Old 11-27-2022, 01:36 AM   #453
IvoryHammer
Drives: '17 BRZ PP
Looks like I'm not crazy, I'll have to try a bit harder to fit it in tomorrow. Thanks for the pictures of your car, it helps!
The Following User Says Thank You to IvoryHammer For This Useful Post:
RToyo86 (11-27-2022)
Old 11-27-2022, 06:22 AM   #454
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
My opinion, better EL 4-2-1.
My Greddy headers work fine fine.
Alastor is offline   Reply With Quote
Old 11-27-2022, 08:33 PM   #455
ihavefat
Drives: 2018 BRZ
I posted on your Reddit post. You should have some room left near the front
ihavefat is offline   Reply With Quote
The Following User Says Thank You to ihavefat For This Useful Post:
Old 11-30-2022, 04:33 PM   #456
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
https://www.instagram.com/p/ClmWLOnuqm1/
Going to leave this here. CSG has tuned a 2nd gen BRZ with these headers on 91 octane and the gains are pretty bananas.
On their conservative dyno, 215whp is no joke!
  • a stock FA24 puts down 186whp on there vs 210-215whp from most Dynojets I've seen
  • for more reference (if memory serves correctly), a stock FA20 does about 150whp, and one with the same JDL 4-2-1 EL header is sitting around 175whp.
Sure makes me jelly of 2nd gen owners!
JBezugs is offline   Reply With Quote
The Following 4 Users Say Thank You to JBezugs For This Useful Post:
Dzmitry (12-01-2022), Pat (11-30-2022), PulsarBeeerz (11-30-2022), RToyo86 (11-30-2022)
Old 12-06-2022, 02:03 PM   #457
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Looks about right to me, I had the titanium color ceramic coating on my first gen header and it matched your color.
Old 12-09-2022, 06:06 PM   #458
jflogerzi
jflogerzi's Avatar
agree!
2013 Series 10 FRS #553
Old 07-18-2023, 08:31 PM   #459
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
What tunes do y'all use for these headers? Planning on buying and have been scouring around for the best ways to get power out of these.
Other than custom, I figure theres:
OFT 2.76 (when they had EL and UEL separate)
OFT 4.03
Wayne (normal short length EL)
Wayne ACE long tube (I think I saw someone mention using this?)
Steve (does he make a tune for this header?)
I'm leaning towards just grabbing a normal EL tune from Wayne but curious about what y'all get results with.
<-- why is this an emote
FeRS is offline   Reply With Quote
Old 07-18-2023, 09:44 PM   #460
Teseo
Drives: frs
OFT 4.03
Yes, Steve can do uel and el as well
The Following User Says Thank You to Teseo For This Useful Post:
Dzmitry (07-26-2023)
Old 07-19-2023, 03:40 PM   #461
FeRS
bruh
FeRS's Avatar
Sick, I just hit him up about tunes for this header
Old 05-19-2024, 01:34 PM   #462
RToyo86
RToyo86's Avatar
GoPro mount on the bumper.
JBezugs (05-21-2024)
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
