Old 11-07-2022, 09:41 PM   #1
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Red starter button?
Has anyone installed one of these red starter buttons into a 2013-2019 BRZ:
https://store.ijdmtoy.com/products/a...sories-gadgets
I've always wanted a red starter button to match the red exterior (and shift knob), but can't justify the >$200 or effort for the complete JDM starter button assembly.
Thanks!
AnalogMan is offline   Reply With Quote
Old 11-08-2022, 01:21 PM   #2
norcalpb
norcalpb's Avatar
The USDM red start button (83031CA024 I believe) is plug and play and *only* $100 + shipping.
I imagine you'll be happier with an OEM piece than the one you listed.
Old 11-08-2022, 04:26 PM   #3
AnalogMan
AnalogMan's Avatar
Probably, but it’s hard for me to justify either spending $100, or the effort to remove the entire starter switch, just to get a red button.
Old 11-08-2022, 07:54 PM   #4
Since the one you linked is just a cover I doubt you can go to far wrong with it.
Old 11-08-2022, 08:58 PM   #5
AnalogMan
AnalogMan's Avatar
It certainly looks like a bargain price I'd be happy to pay. I was wondering if anyone had installed it on their car.
Such as, is complete removal of the starter switch required to swap the buttons? Or can it be done in the car? The only video I found of a similar button showed it being removed with the starter switch out of the car.
The Following User Says Thank You to AnalogMan For This Useful Post:
Tcoat (11-09-2022)
Old 11-09-2022, 01:27 AM   #6
amelo
Drives: '22 BRZ
Not the 1st gen, but I installed a similar button on my 2022 BRZ. I got mine from Import Image Racing, but it looks exactly the same as the one you linked and came with the same hardware.
Here's a video showing how to install it on the 2nd gen, but the process should be the same for the 1st gen.
I'll add that I didn't follow the video exactly. I just left the switch assembly in the car while I removed the button with the wire tool. There's really no reason that you'd need to take the switch out of the car for this. In fact, it might even be easier this way since the switch is held firmly in place, which makes it easier to pull the button out. You also don't have to go through the hassle of taking the assembly out and putting it back in.
amelo is offline   Reply With Quote
The Following 2 Users Say Thank You to amelo For This Useful Post:
AnalogMan (11-10-2022), Tcoat (11-09-2022)
Old 11-09-2022, 08:55 AM   #7
WNDSRFR
Drives: FR-S,GTI
Just paint the damn thing.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Tcoat (11-09-2022)
Old 11-09-2022, 11:57 AM   #8
AnalogMan (11-10-2022), finch1750 (11-09-2022), norcalpb (11-09-2022), x808drifter (11-09-2022)
Old 11-10-2022, 04:48 PM   #9
Sam86
Drives: Toyota 86 GTS
I swapped my 1st gen button with one similar to the one you linked.
The button will come with some tools you can use to pull out the button and push the new one in. I’ll be honest it was way harder to do than expected but it’s possible, nothing needs to be taken apart to do it.
You can get that exact red button for half the price if you get it off Aliexpress (which I would bet is where the retailer you linked get their stock from anyway)
Sam86 is offline   Reply With Quote
The Following User Says Thank You to Sam86 For This Useful Post:
Old 11-11-2022, 08:02 AM   #10
MX-5RACER
Drives: 1999 Miata
I installed a red STi start button in my car. It was pretty easy to do and was under $100 from the dealer.
See my old post here with the part number:
https://www.ft86club.com/forums/show...&postcount=117
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 09-30-2025, 07:04 PM   #11
AnalogMan
AnalogMan's Avatar
Reviving an old thread, curious if anyone has installed a red starter button cover in their Gen 1 BRZ?
I'd go for the genuine OEM part, but now it's $190 thanks to tariffs, and hard for me to justify spending that just for a red button.
There's also this cover, literally a stick-on on top of the old button. Has anyone done one of these?
https://subimods.com/products/subaru...V3ll9phJYVEXeE
Thanks!
Old 10-01-2025, 11:24 AM   #12
norcalpb
norcalpb's Avatar
Thanks!
Hey, it's me again.
I actually installed the red button in my original start button to use as a desk ornament on my work desk. It's neat, but for my actual car I still prefer the more expensive aftermarket one haha. I don't think you can go wrong with either, but be warned I do notice my original start button creaks more every since I opened it up.
I'd personally avoid any of the stick on button covers. They can feel weird.
Old 10-10-2025, 08:33 AM   #13
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I went with the GRMN gt86 button on my first gen.
https://www.ebay.co.uk/itm/286738001...4aAhUnEALw_wcB
autoracer86 is offline   Reply With Quote
Starter button gcranston Interior Parts (Incl. Lighting) 4 08-17-2022 02:13 PM
Trunk button or fob trunk button aren't working. kamilehaula Issues | Warranty | Recalls / TSB 10 10-24-2018 07:33 AM
Part number for the starter button surround Surok Cosmetic Modification (Interior/Exterior/Lighting) 6 12-13-2014 08:38 AM
OEM red starter button DarkestBuddha Cosmetic Modification (Interior/Exterior/Lighting) 4 08-19-2014 04:24 AM
FS: Starter Button - 86 GTS (Australian Spec) Sutty Audio/Visual, Electronics, Infotainment, NAV 8 04-07-2013 01:15 AM
