Old 11-02-2022, 11:54 PM   #1
Sam_
Drives: 2013 Scion Frs
Is A Salvage Rebuild Worth It?
Hi. I am newer to cars, and have done very few small maintenance for my current car. I was wondering if it would be logical to buy a “salvaged” car that has most likely been in an accident. (probably no problems with the engine) and try and rebuild it to try and save some money. I have a lot of space, tools, and a lot of time. I was just wondering what other problems I would run into, and if it is overall worth the risk.
Sam_ is offline   Reply With Quote
Old 11-03-2022, 12:23 AM   #2
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
Dadhawk (11-03-2022), DarkPira7e (11-03-2022), EAGLE5 (11-03-2022), NoHaveMSG (11-03-2022), pope (11-05-2022), PulsarBeeerz (11-03-2022), soundman98 (11-03-2022), Tcoat (11-03-2022), x808drifter (11-03-2022)
Old 11-03-2022, 08:15 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Old 11-03-2022, 09:13 AM   #4
Old 11-03-2022, 09:19 AM   #5
Rebuilding a salvage car is not nearly as straight forward as it may seem even if no engine damage.
Bent structure, cut harnesses, airbag modules, etc all take more than "I can change oil" levels of skill and specialized equipment to deal with.
The guys with that equipment and skills make it look really easy. It ISN'T!
In the long run you will find that you will probably not save much money and the probability of the project ending up as a tarp covered lawn ornament and animal condo is high.
If you want to learn buy an older beat up but functioning one and practice the basics.
soundman98 (11-03-2022), Ultramaroon (11-03-2022), Wally86 (11-03-2022), x808drifter (11-04-2022)
Old 11-03-2022, 03:05 PM   #6
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I wouldn't. I did basically this with my FR-S that I totalled on the track in 2020. It was worth it to me because the sentimental value tied to the car, but I would have been really stupid to invest all of this money otherwise. Unless you're a professional and your time is "free" rebuilding a salvage title car isn't going to pay off unless you cut corners.
gkubed is offline   Reply With Quote
The Following User Says Thank You to gkubed For This Useful Post:
Tcoat (11-03-2022)
Old 11-03-2022, 05:37 PM   #7
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If you have the skills and time, absolutely.
But be aware, there are a bunch of partially finished salvage rebuilds that go up for sale frequently because the person didn't really know what they were getting into...me & @Dave-ROR make it look easy. But there are hurdles on some rebuilds that many can't overcome due to knowledge, skills, equipment, etc.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
bcj (11-03-2022), soundman98 (11-03-2022), Tcoat (11-03-2022)
Old 11-03-2022, 08:09 PM   #8
Sam_
Would you have any suggestions when looking for a salvaged car. I have heard airbags can be difficult and costly. I have also seen that some cars that seem to just have damage to the body ended up having frame damage aswell which does not sound fun.
Old 11-03-2022, 09:02 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Airbags are cheap. Myairbags.com can reset the computer. Clockspring can be fixed but can fail again... seatbelt pre tensioners are like 50 each to fix.
Rear end repairs suck, front end arent terrible. Avoid anything with lower front end damage (likely frame rail and apron damage) or abs module damage (thats out of laziness on running new brake lines though).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
bcj (11-03-2022), Opie (11-04-2022), soundman98 (11-03-2022)
Old 11-04-2022, 06:35 AM   #10
gt86ser
gt86ser's Avatar
Drives: Toyota 86
Totally worth it, I picked up 3 months ago a 1 owner 2015 Scion FRS 1 with 80k on it, won it for $5200, fixed it with $2600 with new and used OEM parts, airbags never deployed, had front end damage, car was totaled for 9k in damages, decided to go with 2017 front end, it was an easy fix, sourcing the used oem parts was the bad part, but's it done.
gt86ser is offline   Reply With Quote
Old 11-04-2022, 08:54 AM   #11
Opie
Opie's Avatar
Go physically look at the car before bidding, know what you are looking at and looking for.
The Following User Says Thank You to Opie For This Useful Post:
Tcoat (11-04-2022)
Old 11-04-2022, 09:17 AM   #12
That's just it and sort of the point of my first post. If somebody is asking the question the OP asked then it is very, very, probable they don't know what they are looking at or what to look for.
Threads like yours make rebuilds look really easy, fast, and inexpensive and they certainly can be for those that KNOW what they are doing.
If somebody is "newer" to cars and experience consists of changing some oil then jumping into a rebuild is getting way ahead of themselves. Sure people need to do things to learn but the wrong rebuild for the skill level invaribly leads to a poor or abandoned project.
A far better jumping off point would be to get a reasonably priced high mileage but fully intact car and start replacing worn parts to build it up. This really applies if budget is an issue as it appears to be in this case.
Dave-ROR (11-04-2022), Opie (11-04-2022), pope (11-05-2022), x808drifter (11-04-2022)
Old 11-04-2022, 10:01 AM   #13
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I don't know about DMV laws in NE but in Va, retitling a car as rebuilt or salvage is a PITA.
4 years ago, I got my FRS by making friends with a small local used car guy. He searched auctions for "as is" BRZ/FRS/86's. We found mine in Texas for $6k. It was a repo with an open recall on the valve springs but it actually ran just fine. With shipping, auction fee, and $500 to my guy I had $7500 in it.
The Following User Says Thank You to blsfrs For This Useful Post:
Tcoat (11-04-2022)
Old 11-04-2022, 10:10 AM   #14
That is EXACTLY the sort of scenario I have been saying.
Checking the private sales market is another option. I sold my FRS for a very reasonable price since it was high mileage and had a few small battle scars. The new owner got a decent and fully intact car for far less than they would have if buying retail from even the shadiest used car dealer.
They can be had with some looking.
blsfrs (11-04-2022), Opie (11-04-2022)
Worth trying to rebuild? Gloonge Engine, Exhaust, Transmission 17 12-27-2020 12:03 PM
Salvage BRZ DenisSlob4 BRZ First-Gen (2012+) — General Topics 15 06-04-2019 02:58 AM
Salvage Rebuild + Limited Swap BlueRepairZone Member's Car Journals 3 01-13-2019 10:58 PM
buying salvage twin for track worth it? WATCHMEHEAL Tracking / Autocross / HPDE / Drifting 15 09-03-2013 03:31 PM
brz salvage hunter3232792 BRZ First-Gen (2012+) — General Topics 4 10-13-2012 09:41 PM
