Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-01-2022, 04:47 PM   #29
KillerBMotorsport
KillerBMotorsport's Avatar
Another 3K miles, another little puddle out of the rear AOS. Nearly all street/commuting miles...
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
x808drifter (11-01-2022)
Old 11-02-2022, 11:59 AM   #30
BioRebel
Drives: Mini Cooper S
Do these cars have that much of a buildup issue? I'm coming from a 2010 mini cooper where a catch can was kind of required.
BioRebel is offline   Reply With Quote
Old 11-02-2022, 02:37 PM   #31
KillerBMotorsport
This depends on who you ask. For those that want all the internals clean and no chance of knock, and optimized performance (real, theoretical, or otherwise), it's important. Others feel it's not important. Really depends on where you fall on that scale and your budget tolerance.
Old 11-25-2022, 12:29 PM   #32
KillerBMotorsport
PSA for those not on our mailer. We're having a 20% off Black Friday sale on all oiling products. Thanks for the support!
Old 12-28-2022, 09:29 AM   #33
KillerBMotorsport
We have these back in stock. Thanks everyone!!
blsfrs (12-28-2022)
Old 12-31-2022, 06:19 PM   #34
tazio
Drives: Don't yet have a Toyobaru
If 3,000 miles worth of separated oil is one forum-standard "puddle," what's the capacity of the AOS? Enough for the recommended oil change interval, absent track use?
tazio is offline   Reply With Quote
Old 01-02-2023, 09:57 AM   #35
KillerBMotorsport
We always recommend checking the drains at each oil change or after a track day, until you establish a baseline that is specific to you. Varying environmental, driving style, engine wear, oil type, power level, etc... will all play a role in how much you collect.
You might find that you can drain every other oil change, or if you just commute and drive like granny, you might be able to get away with once a year.
I'm home right now and don't have the max capacity handy but draining every oil change and after a track day, you should come nowhere near the unit's max capacity.
Old 01-02-2023, 12:59 PM   #36
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
One extremely important thing worth noting is that in cold climates, these(catch cans in general) have a potential to collect a lot of moisture that will smell like gas. Do not let it get full
Old 01-02-2023, 02:22 PM   #37
KillerBMotorsport
These units are not open to atmosphere. The only time you would smell gas, is when you drain them.
DarkPira7e (01-02-2023)
Old 01-02-2023, 02:32 PM   #38
DarkPira7e
DarkPira7e's Avatar
Sorry- I wasn't inferring they smell normally, just when you open
Old 01-07-2023, 10:23 PM   #39
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
I just did an HPDE today on a CCW course with mostly high speed sweepers. After my last session, I parked for ~25-30min before leaving. Upon starting my car to leave, I observed a cloud of blue smoke on startup. It cleared up pretty quick so I immediately thought of this issue. When I got home I popped the intake and sure enough, a small amount of oil at the bottom of the intake tube.
So, based on my experience I would say yes. FWIW my car has a touch over 1000 miles, 2023.
I will probably give this solution a try.
nissanfanatic is offline   Reply With Quote
The Following User Says Thank You to nissanfanatic For This Useful Post:
BioRebel (01-10-2023)
Old 01-09-2023, 10:13 AM   #40
KillerBMotorsport
No one likes the dreaded puff!
Thank you for your patronage. If you have any questions about the product or install, please don't hesitate to reach out to us.
nissanfanatic (01-09-2023)
Old 01-13-2023, 09:20 AM   #41
nissanfanatic
Drives: 2023 BRZ
Just ordered the dual kit. Have a track day at the end of the month so looking forward to testing it out!
Old 01-19-2023, 08:06 AM   #42
KillerBMotorsport
Awesome, thanks so much for the support!
If you have any questions during install, drop us a PM.
nissanfanatic (01-19-2023)
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 08:40 AM
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 50 10-29-2022 08:36 AM
Killer B Motorsport Carbon Fiber Strut Braces KillerBMotorsport Groupbuys 17 10-25-2022 11:05 AM
FREE Delrin Shift Knob - Killer B Motorsport KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 56 04-27-2022 07:32 AM
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 10:51 AM
