Old 08-31-2022, 07:43 PM   #15
Decep
Drives: 2013 FR-S Series 10
Originally Posted by Grady View Post
Go to your battery specifications. It will tell you max charge voltage and recommended float voltage. Then find a charger that falls into those specifications. It is best to get a charger that has temperature compensation. I have always had good luck with Battery Minders. They cost more but also help reduce battery sufidation.
I had an odyssey AGM battery that was super picky about charging voltage and specified a minimum voltage too.. otherwise it would sulfate and somehow void your warranty.
I only found 2 or 3 chargers that would hit their spec.. besides the ones Odyssey themselves manufacture. Ended up just getting their charger randomly on supersale at amazon anyways.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 08-31-2022, 11:36 PM   #16
radroach
Drives: car
I recommend installing a ring terminal fused SAE connector for easily connecting your chargers. This is preferable to leaving alligator clips attached to your race car. My charge connectors poke out of the hood cowl.
And I also use a 25 foot SAE extension cable. This allows me to run my cables outdoors without having my chargers exposed. Since the connections are fused, I have less to worry about with short-circuiting.
The "Battery Tender" brand waterproof chargers are the best for long-term maintaining. They are waterproof, and mine has lasted 20 years outdoors. They charge at about 10 watts, and maintain your battery at a float charge.
The chinese branded battery chargers are pretty great to own too. I have a Foxsur charger that can do both 12v and 24v charging, at 6 amp. Or 60-70 watts on a 12v battery. I plug my car up to this charger 30 min before starting the car every day, and it definitely puts some juice into the battery - I figure this helps somewhat so I do it routinely.
Another thing to note is avoid old "heavy duty" battery chargers like the kind grandpa had in his garage he bought from Sears 35 years ago. Example is the one my grandad had, that when I plugged in it boiled my car battery at 15.5 volts.
These older chargers have poor voltage regulation. and will boil your battery at 15+ volts and can hurt electronics. It almost fried my truck's electronics before I started looking into it and running a voltmeter on it. Having a good voltmeter is a handy tool for checking battery health.
The Following User Says Thank You to radroach For This Useful Post:
jflogerzi (09-12-2022)
Old 10-17-2022, 10:39 AM   #17
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
The only problem I'm personally seen with a battery maintainer, was one hooked up to a pair of AGM's for an RV. the maintainer was undersized and couldn't push the batteries hard enough to switch over to the float/maintain cycle. Just cooked them after a couple months.
Shouldn't be an issue with a single small AGM.
Breezio is offline   Reply With Quote
SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray timepoor Audio/Visual, Electronics, Infotainment, NAV 4 10-06-2021 11:40 PM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Ridge Racing School; Lapping/school Sept 7th rice_classic Northwest 4 09-05-2012 02:27 AM
