#4383 | |||
Drives: 2018 Subaru BRZ
This is actually pretty cool info. Thanks! Still lots of questions. Quote:
It is. Im reading the RCE guidelines and gotta say, Im not much of a learning while reading person. Im more practical. I think the best way to learn would be to hangout with people who did this for a living. To see and tinker with this stuff in person.
| The Following User Says Thank You to spcmafia For This Useful Post: | Ultramaroon (10-14-2022) |
#4384 | |
Drives: Crapcan
For most people, leaving settings at baseline and tuning with sway stiffness is enough, maybe a couple clicks here or there off the baseline damper settings.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#4385 | |
I do actually have ACC. Might give it a try.
#4386 |
Drives: Crapcan
Make sure it is a car/track you are familiar with. Trying to figure out a new car or track while also trying to feel out adjustments compounds the issue.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | bcj (10-14-2022), x808drifter (10-14-2022) |
#4387 |
30 minute maintenance
Drives: My18 wrxsti
#4388 | |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#4389 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (10-14-2022) |
#4390 | |
LMGTFY
Drives: 13 FRS, 91 Miata
I've been studying/doing this shit for 2 decades and still am learning. I will say when it comes to video games GT7 is not where you should be looking. Aim for a real sim on PC. AC, ACC, iRacing are good. At least with games there is no need to worry about springs being to strong for your dampers. XD Suspension is like areo. The more you know the less you know. |
| The Following 6 Users Say Thank You to x808drifter For This Useful Post: | NoHaveMSG (10-14-2022), soundman98 (10-15-2022), spcmafia (10-15-2022), Spuds (10-14-2022), Tcoat (10-14-2022), Ultramaroon (10-14-2022) |
#4391 | |
It's still good to know how little one knows.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#4392 |
The Dictater
Drives: '13 Red Scion FRS
Disclaimer, I probably have no idea what I'm talking about, but I have done pretty much what you are looking at and here's my advice.
To get you started: Recommend a flat track (no elevation changes/banking) with different length corners at different speeds. You want no aero on the car because that is a whole different game. Pick a RWD car. I am intentionally leaving toe adjustment out until the end. There are two goals for racecar (comfort and feel are hard to do in sim I think): -Achieve highest steady state grip in lateral and longitudinal directions. -Achieve smooth and predictable transient load conditions Start looking at steady state, mid corner performance first. Pay attention on solitary fast sweepers and slow >90° turns, and ignore everything else. First mess with the front/rear balance of the following: Sway bars, spring rates, camber. Then adjust them up and down as a whole, then go back to changing balance. Next, look at corner entry. You are looking at slow, longer corners following a braking zone with the main parameter being how late you can brake and still follow the racing line with only smooth inputs. Parameters to mess with are: Spring rate overall, spring rate f/r balance, front bump damping, rear rebound damping, camber overall, caster. Note that some beneficial adjustments here might actually be to the detriment of mid-corner balance and performance. Once you figured out how settings affect you here, go back and forth to find a good balance. Third, look at corner exit, particularly from medium speed corners onto a straight. Obviously you want to be able to put the most power down to get the highest speed coming out. Here you want to adjust: rear sway bar, spring balance, front rebound damping, rear bump damping, rear camber. Once you found a happy zone, go back through the other two phases, see the effect, and find a balance. Last is quick direction changes. S curves, chicanes, etc at varying speeds. You want the car to change direction as quickly as possible while remaining stable through the second/third/etc curve. This is where damping really comes into play (at least on a race track). Adjust damping overall first, then balance, then look at spring and sway rates, then adjust damping again. As before, go back to the other phases and find a good balance. Toe. I look at this as a last resort to attempt to make an axel just a bit more or less stable, mostly because I would probably always leave it at 0 on a real street car. Toe out typically makes that axel want to change directions a bit more, while toe in makes it more resistant to changing directions. You can try it out, but I recommend learning how everything else affects the car first. Maybe add in elevation and/or banking and see what things do? Lol. Embrace the madness. Once you have figured out one car, repeat with a few others with different weight distributions and geometries. Then you can try fwd, awd, aero, etc. Warning it's addicting. Edit: Now change the tire compound and do it all again. Fun fact, EVERYTHING depends on the tires. Last edited by Spuds; 10-15-2022 at 03:10 AM. Reason: Spelling, grammar, etc. |
| The Following 4 Users Say Thank You to Spuds For This Useful Post: |
#4393 |
I love your systematic approach. It takes real passion to master a skill via sim.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Spuds (10-15-2022), x808drifter (10-16-2022) |
#4394 | |
#4395 | |
ProCrastinationConsultant
half the time, i don't know what i'm adjusting, or if it's good or bad, i just adjust it until it feels right!
#4396 |
The Dictater
| Tags |
| have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
| Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 12:00 PM |
| OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-27-2017 12:33 AM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 08:35 PM |
