Old 10-14-2022, 11:26 AM   #1
Chezboat24
Click Here
2013 FRS Intermittent no-crank
As the title states, having issues with my FRS regarding an intermittent no crank. Starter will only turn about 10% of the time when I turn the key. When it does turn, it’s starts up and is completely fine. There’s no grinding or spinning noise when turning the key so I think it’s a connector issue. Just wondering what else to rule out given the circumstances. I believe this is still the original starter so it’s possible that it just needs replacing anyway.
Chezboat24 is offline   Reply With Quote
Old 10-14-2022, 01:24 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Do the dash lights come on when you turn the key on? Do they dim when you try to start the engine? Are you pushing the clutch pedal aaaaalllllll the way to the floor every time?
Old 10-14-2022, 01:58 PM   #3
Chezboat24
Click Here
Car otherwise works perfectly. Battery is strong, dash lights are fully functional. It didn’t occur to me that I’m not pushing the clutch all the way down - I did drive in my steel toes this morning…
Funny enough, it hasn’t replicated since, so you might be right. I checked the spot at which the starter engages and it’s only at about 2/3 throw - I hope that’s all it is but I’m finding that hard to believe.
The Following 2 Users Say Thank You to Chezboat24 For This Useful Post:
blsfrs (10-14-2022), soundman98 (10-15-2022)
Intermittent no-crank/no-start 2013 BRZ Limited tobin Issues | Warranty | Recalls / TSB 5 07-27-2021 11:28 AM
BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD MJones_RB Engine, Exhaust, Bolt-Ons 3 03-31-2021 04:07 AM
2013 scion FRS intermittent p1235 140db86 Issues | Warranty | Recalls / TSB 1 12-08-2020 06:13 PM
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 06:57 AM
BUDDY CLUB P1 CRANK PULLEY KIT: SCION FR-S & SUBARU BRZ 2013-UP (W/AC) syndicatemotorsports Engine, Exhaust, Bolt-Ons 6 07-03-2014 04:26 PM
