Drives: 2013 FRS
4th Break light Causing Dash Lights
Hi, I've had the phastek 4th brake light kit installed for years. At some point soon after installing the bulb burnt out so I didnt notice any issues. Recently I installed a wirring harness and removed the taps. I shrink wrapped the areas where the only taps were. When doing this I noticed the burnt out bulb.
Since replacing the bulb I noticed the clock lights would turn off and the back lit buttons on the headunit would turn on when I hit the brakes. Removing the 4th brake light would correct this. Lately I noticed when I turn the head lights on the slip light and abs light come on instantly. This is also corrected by disconnecting the 4th brake light. I tried and led buld instead of halogen and it seems to have fixed the clock issue. But still causeing the slip and ans light to come on when the head lights are turned on. Anyone have any ideas. The only thing I havent tried is a resistor kit I can get for the led bulb. I just wouldn't know where to mount it since it gets hot and said shouldnt be mounted near plastic or wiring. |
#2 |
Wheels for Brains
Check that your removed taps aren't crossing/shorting
Check the wiring on the harness to make sure they are tied into the system properly and not causing a short to ground or feedback Most LED bulbs have built in resistors to keep the diodes from burning out from too much draw. |
#3 |
ProCrastinationConsultant
no, not really... but also not the point of this either.
| The Following User Says Thank You to soundman98 For This Useful Post: | x808drifter (09-28-2022) |
| Does anybody know what is causing the massive backlog for Helix/Valenti lights? | texastwurkt3am | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 11-21-2018 12:55 PM |
| Third brake light causing rattle | BIL90 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 11-28-2016 11:27 AM |
| FS: Oem head & tail lights, break light & side marker | Vesalera | Exterior Parts (Aero, Lighting, Etc.) | 6 | 04-17-2015 11:52 AM |
| CAI causing check engine light | ZombieBadger | Issues | Warranty | Recalls / TSB | 13 | 01-18-2015 07:20 PM |
| Major bump in the road causing TPMS light? | Chauntalei | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-20-2013 12:56 PM |
