| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#785 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (09-20-2022) |
#786 |
At redline you're looking at ~2 gallons/min or 8 quarts/min. It's not a lot. The pump actually moves a LOT more than that when bench tested, but most of the oil goes out the bypass valve when on an engine.
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | ROFL it's Waffle (09-22-2022) |
#787 | |
#788 | |
Drives: 2022 GR86
I feel like you could easily pour 2 gallons a min through a blocked tube, without a pump helping it along. I wish a subura/toyota engineer would come out an say how the tube was tested. |
#789 |
#790 |
Drives: '22 BRZ
If the pump is moving a LOT more than 2 gal/min at redline but bypassing much of it... that oil still needs to pass through the oil pickup tube.
The FA20DIT flows 15.9 GPM at redline, no clue if the FA24 is more or less. and sucking through a restriction is a lot different than blowing through or even just free flowing through it.
| The Following User Says Thank You to DocWalt For This Useful Post: | Tcoat (09-21-2022) |
#791 |
Drives: 2022 GR86
I've worked on cars most of my life, but never to the level of building an engine. I wish there was an animation or video showing how the oil moves through a boxer engine. Curious to see how it flows.
#792 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Can the pump fail if it's running dry? (is the pump cooled by the oil)
#793 | |
Not to say they can't fail but overheating them would be a pretty good achievement.
| The Following User Says Thank You to Tcoat For This Useful Post: | ROFL it's Waffle (09-27-2022) |
#794 |
#795 | |
Drives: '22 BRZ
also, positive displacement pumps always move the same amount of fluid given the same fluid conditions and RPM. They'll just generate more pressure (which gets relieved out the bypass when not needed)
#796 | ||
It's PD all the way.
#797 | ||
From sump, to pump, filter, LH head, block, to RH head. This is the path and order across the main galleys.
No. Bypassed oil goes right back into the suction side of the pump. It's all contained within the pump. Quote:
It does not open at 140psi. Here's a plot showing oil pressure. Where the ramp rates change is where the bypass just cracks open and starts regulating. I would call it 75psi... which coincidentally, it right in line with 95% of the other oil pumps Subaru uses. The reason pressure keeps climbing after the bypass opens is because flow is increasing, further compressing the bypass spring, requiring more pressure to keep it open enough for the additional flow. Eventually what can happen is the bypass will aerate (if you have too big of a pump and an engine not made for it, for example), because flow out the bypass is horribly turbulent. Think of water coming out of a hose with your thumb covering the end. If you run too big of a pump AND shim it to increase pressure, then that inner gerotor usually lives a short and violent life. Flow is linear with RPM through the rotors (assuming constant temp and no AVCS). The bypass valve regulates the pressure and flow actually going into the engine. |
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | Petah78 (09-22-2022), Ultramaroon (09-22-2022) |
#798 |
I don't have any comparative oil pump data for the FA24 yet, but here's one from an EJ (2019 STi) showing a 10mm, 11mm, and 12mm pump on the same engine.
And here's a No-Load plot showing the point that the bypass valve starts regulating oil pressure... |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Petah78 (09-22-2022) |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
