timurrrr
Old 09-20-2022, 12:09 PM   #785
Originally Posted by Spektyr View Post
I could be wrong, but my understanding of fluid dynamics would say that there's a fairly small range of variation in diameter that would work. The inlet/outlet diameter of the oil pump itself is a big factor. At some point you have to funnel the pickup tube up/down to that size.
As your pickup tube diameter increases beyond the size of the oil pump inlet you're going to see less flow around the outside because the pump cannot lift the entire volume of oil in the tube uniformly. The height of the column of oil is set, so the wider you make the pickup the heavier that much oil becomes and the pump has only so much lifting power. The result will be a column of oil within the total volume that actually moves upward, concentrating any particulates or chunks suspended in the oil to that part of the screen.
As the center of the screen gets blocked, the column will "hunt" around for an unblocked path, kind of like a tornado looking for a trailer park.
Again, I'm not certain, but my guess would be that the smoothest, most efficient (laminar) flow would be achieved when the tip of the pickup tube is at or very close to the same surface area as the inlet of the oil pump, so I doubt that it's undersized.
In summery
soundman98 (09-20-2022)
Old 09-20-2022, 04:15 PM   #786
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by ROFL it's Waffle View Post
Noob questions: I see the diameter of the pickup tube. How much oil is being sucked up at once? Is it a slow suction or fast? (not sure how to quantify this, maybe in cups per second or quarts per minute?)
At redline you're looking at ~2 gallons/min or 8 quarts/min. It's not a lot. The pump actually moves a LOT more than that when bench tested, but most of the oil goes out the bypass valve when on an engine.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
ROFL it's Waffle (09-22-2022)
Old 09-20-2022, 05:06 PM   #787
KillerBMotorsport
Originally Posted by Grif View Post
A close up and personal inspection of the oil pickup screen/basket.
Really gives you perspective of the surface area at play.
https://twitter.com/yonsama800/statu...69665373138945
Any chance you have some calipers and can measure the size of the open squares? Curious how close this is to the wire mesh used on past oil pickups.
Old 09-21-2022, 11:46 AM   #788
_____That_-_GUY_____
Drives: 2022 GR86
At 2 gallon/min, I can't see that there would be any issue with the oil cleanly finding a path through the screen, even if the top was completely blocked.
I feel like you could easily pour 2 gallons a min through a blocked tube, without a pump helping it along.
I wish a subura/toyota engineer would come out an say how the tube was tested.
_____That_-_GUY_____ is offline   Reply With Quote
Old 09-21-2022, 02:34 PM   #789
KillerBMotorsport
^ correct. 2 gal/min is not a lot.
Old 09-21-2022, 03:17 PM   #790
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
If the pump is moving a LOT more than 2 gal/min at redline but bypassing much of it... that oil still needs to pass through the oil pickup tube.
The FA20DIT flows 15.9 GPM at redline, no clue if the FA24 is more or less.
and sucking through a restriction is a lot different than blowing through or even just free flowing through it.
The Following User Says Thank You to DocWalt For This Useful Post:
Tcoat (09-21-2022)
Old 09-22-2022, 09:13 AM   #791
Drives: 2022 GR86
I've worked on cars most of my life, but never to the level of building an engine. I wish there was an animation or video showing how the oil moves through a boxer engine. Curious to see how it flows.
Old 09-22-2022, 10:47 AM   #792
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Can the pump fail if it's running dry? (is the pump cooled by the oil)
ROFL it's Waffle is offline   Reply With Quote
Old 09-22-2022, 12:45 PM   #793
It would have to run dry for a long long time(longer than the engine would run). It is a gear type pump that doesn't spin as fast as a rotary impeller or piston pump.
Not to say they can't fail but overheating them would be a pretty good achievement.
ROFL it's Waffle (09-27-2022)
Old 09-22-2022, 04:20 PM   #794
KillerBMotorsport
That is the bench figure. No restrictions (like an engine), and no bypass flow.
Old 09-22-2022, 04:42 PM   #795
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Again, bypass flow still has to go through the pickup.
also, positive displacement pumps always move the same amount of fluid given the same fluid conditions and RPM. They'll just generate more pressure (which gets relieved out the bypass when not needed)
Old 09-22-2022, 06:55 PM   #796
I don't think the fa20 has a regulator, There's only the relief valve which I understand opens at 140-ish PSI. If it had a regulator, pressure would not fluctuate dramatically with RPM and temp. It would also not hit 120 PSI at high idle on cold start.
It's PD all the way.
Old 09-22-2022, 07:16 PM   #797
KillerBMotorsport
From sump, to pump, filter, LH head, block, to RH head. This is the path and order across the main galleys.
No. Bypassed oil goes right back into the suction side of the pump. It's all contained within the pump.
That would be true if it weren't dynamic, but the pump is constantly changing RPM. Not only that, but the system's flow rate also is changing due to temperature and AVCS demand.
Some call it a regulator, some call it a bypass. It's the same thing.
It does not open at 140psi.
Here's a plot showing oil pressure. Where the ramp rates change is where the bypass just cracks open and starts regulating. I would call it 75psi... which coincidentally, it right in line with 95% of the other oil pumps Subaru uses. The reason pressure keeps climbing after the bypass opens is because flow is increasing, further compressing the bypass spring, requiring more pressure to keep it open enough for the additional flow. Eventually what can happen is the bypass will aerate (if you have too big of a pump and an engine not made for it, for example), because flow out the bypass is horribly turbulent. Think of water coming out of a hose with your thumb covering the end. If you run too big of a pump AND shim it to increase pressure, then that inner gerotor usually lives a short and violent life.
Flow is linear with RPM through the rotors (assuming constant temp and no AVCS). The bypass valve regulates the pressure and flow actually going into the engine.
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
Petah78 (09-22-2022), Ultramaroon (09-22-2022)
Old 09-22-2022, 07:21 PM   #798
KillerBMotorsport
I don't have any comparative oil pump data for the FA24 yet, but here's one from an EJ (2019 STi) showing a 10mm, 11mm, and 12mm pump on the same engine.
And here's a No-Load plot showing the point that the bypass valve starts regulating oil pressure...
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
