| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 |
Drives: 2022' GR86 Premium 6MT
While we are on the topic, how much oil would you guys suspect would actually be too much and cause harm? It's my understanding that too much oil can
- increase oil pressure - cause air pockets (failed lubrication) - froth up
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#16 |
ProCrastinationConsultant
starting to get into a guessing game.
i wouldn't worry about it unless it's frothy on the dipstick.
#17 | ||
Proud of BOXER
Drives: Subaru Boxer
I believe you'd have to overfill by an entire quart to begin seeing those things happening.
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | Ultramaroon (09-21-2022), x808drifter (09-21-2022) |
#18 |
LMGTFY
Drives: 13 FRS, 91 Miata
And FIY Hole to hole on a dip stock is 1 quart for every car I've seen.
| The Following User Says Thank You to x808drifter For This Useful Post: | Spektyr (09-21-2022) |
#19 | |
If you were so overfull that it causes an issue you would know by now.
#20 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Put your dipstick in, pull it out, and wipe it about 50-100 times.
NARFALICIOUS
Noob Poster 1988 | 2016 |
| The Following 6 Users Say Thank You to NARFALICIOUS For This Useful Post: | Dzmitry (09-22-2022), soundman98 (09-21-2022), Spektyr (09-22-2022), Ultramaroon (09-22-2022), VoltsFRS2013 (09-21-2022), Wally86 (09-28-2022) |
#21 |
Drives: Crapcan
Pretty sure it is more than that, I know guys that intentionally run a quart high. There is the oil pan, the upper oil pan, and then the outside of the crank is about an inch above that.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (09-21-2022) |
#22 |
Drives: '13 Whiteout
As long as the crankshaft isn't hitting the oil in the pan you're ok.
| The Following 2 Users Say Thank You to TommyW For This Useful Post: | soundman98 (09-21-2022), x808drifter (09-22-2022) |
#23 | ||
Proud of BOXER
Why would you want to intentionally run a quart high?
#24 |
Oil pools in the heads when cornering. Another quart is insurance against starvation.
#25 |
LMGTFY
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | soundman98 (09-23-2022), Ultramaroon (09-23-2022) |
#26 |
Just the tip
Drives: 2017 DGM BRZ
You'll be fine.
This is another good argument for a quick drain valve though. Slight overfill? Easy to drain a little without a full change. |
| The Following User Says Thank You to wolffbite For This Useful Post: | Spektyr (09-23-2022) |
#27 |
Drives: Crapcan
Oil starvation. I don't do this, I just know of others that swear by it.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Clipdat (09-24-2022) |
#28 |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Rookie in need of suggestions! Please help. | Artxjr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 03-01-2019 03:51 PM |
| Subaru ROOKIE | BRZParee2019 | BRZ First-Gen (2012+) — General Topics | 29 | 10-15-2018 11:40 AM |
| Spacers rookie mistake | Impureclient | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-03-2016 01:55 PM |
| Help out a rookie? | Outride | Forced Induction | 37 | 02-04-2015 01:04 PM |
| Adventures of a rookie in Autocross | djfuller | Tracking / Autocross / HPDE / Drifting | 9 | 04-01-2013 09:30 PM |
