Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-20-2022, 11:45 AM   #29
Originally Posted by Dzmitry View Post
But it is interesting, because the lip is literally tiny as hell. Maybe 1-2 inches out past the connection points? I'm just basing that off of a picture of one. The car is quite high up off the ground as well and based on OPs photo, he looks to be at stock ride height. If he were to scrape the ground due to a slope or something going at such speeds, That would only be a scrape from the bottom. But as many mentioned, it has to be something that caught it and ripped it down under. OP states he has no screws/bolts/whatever left aside from one. And as far as I understand, sounds like OP endured no damage whatsoever to the bumper. So it had to be the cleanest hit ever to catch the half inch of lip that pokes out, rip it clean off with all the hardware, and have no effect on the bumper at all.
Might be harder to see from my photo, but my bumper did endure some damage even though the object barely caught my lip. In fact, it tried to pull the whole bottom portion down, and you can see the bottom grille popped out of its clips. The bumper also endured solid scrapes and paint fully rubbed off near the connection points of the lip.
Ya the thinness of it is what makes it hard for me to believe that there was enough air pressure to just rip it off. Unless he hit mach 1 of course.
If there was a picture of the remains it may be more clear what happened but my guess is that anybody going that fast isn't going to bother to go back and clean up their mess.
Dzmitry (09-20-2022)
Old 09-20-2022, 11:47 AM   #30
slimfit
Drives: ‘22 BRZ
I recently installed mine. Not a fan of the wellnuts using compression to hold this thing in place. It’s possible whoever installed it made the holes too big and they let loose. I followed the instructions to the T and still managed to loose a nut and screw during normal driving. Definitely planing on replacing everything with bolts and locking nuts for some peace of mind.
slimfit is offline   Reply With Quote
The Following 4 Users Say Thank You to slimfit For This Useful Post:
DylanJZA (09-29-2022), Dzmitry (09-20-2022), Midnightsky (09-21-2022), Tcoat (09-20-2022)
Old 09-20-2022, 12:44 PM   #31
chipmunk
Drives: _
This won't be a comforting post, but... you can feel relieved that nothing else got damaged in the process. Yes those lips aren't cheap, but think about how much worse it could have gotten.
chipmunk is offline   Reply With Quote
Old 09-20-2022, 01:37 PM   #32
BioRebel
Drives: Mini Cooper S
Note to self, don't get the sti front lip its apparently a flimsy pos
BioRebel is offline   Reply With Quote
The Following User Says Thank You to BioRebel For This Useful Post:
Old 09-20-2022, 01:38 PM   #33
I hit a duck at speed with my Lancer once. It knocked the fog light housing into the wheel well which took out the brake line, wheel sensor and fender liner.
Things could certainly be worse.
soundman98 (09-20-2022)
Old 09-20-2022, 01:44 PM   #34
BioRebel
Originally Posted by KOUKIBLUEBRZ View Post
I've had the car for a month now and last weekend my front lip just decided to commit suicide while running at 220km/h. The dealer installed the lip before I took delivery of the car and they don't want to take responsability for waht happened. I've never scrapped or touched the lip beforehand. Am I crazy to think that the dealership should take responsability for that?
I'd call Subaru corporate and try to get some warranty info on the thing. Can't hurt.
Old 09-20-2022, 03:52 PM   #35
chipmunk
Drives: _
Safe to say your Lancer got ducked up pretty bad...?
The Following User Says Thank You to chipmunk For This Useful Post:
Old 09-20-2022, 03:55 PM   #36
Had a big quack in the bumper yes.
DylanJZA (09-29-2022), MyHybridBurnsGasAndTires (09-20-2022), soundman98 (09-20-2022), whataboutbob (09-21-2022)
Old 09-20-2022, 11:20 PM   #37
soundman98
ProCrastinationConsultant
soundman98's Avatar
if it uses those wellnuts, those are less than useless. my armrest included, i've never had an install with those that a bored toddler couldn't pull them out..
and i drilled my armrest wellnut holes 1-size smaller and forced the nuts in to try to provide some amount of friction-fit.
my suggestion? get better mounting hardware, but next time, it'll take the entire bumper off...
slimfit (09-21-2022)
Old 09-21-2022, 12:26 AM   #38
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
This is possible. Even a slight rise in the road surface could catch it and BOOM. There isn't enough profile for the wind (even at that speed) to rip it off on it's own but deformation and contact would do the job.
And it is on Quebec roads, in Canada.
Midnightsky is offline   Reply With Quote
Old 09-21-2022, 12:15 PM   #39
slimfit
Drives: ‘22 BRZ
I’m planning of that for sure……BUT, what if it’s designed this way so you don’t rip off your bumper. If OP did hit something, it seems to have worked flawlessly.
The Following 2 Users Say Thank You to slimfit For This Useful Post:
soundman98 (09-21-2022), Tcoat (09-21-2022)
Old 09-21-2022, 12:20 PM   #40
I would much rather lose a lip than crack a bumper cover!
Old 09-21-2022, 04:01 PM   #41
mycrors7
mycrors7's Avatar
Drives: zd8 brz
properly installed wellnuts will hold in body panels/pieces just fine. you have to be VERY careful when drilling holes for wellnuts. if theyre not next to perfect, they will cause issues.
like i mentioned earlier, if i yank my lip hard enough, it will want to pull my bumper off... and it's installed with the factory wellnuts.
i always drill small and slowly shave away with the smaller drill bit until i can barely get it in.
wellnuts have held in expensive widebody kits for many people in the past, and they offer some form of protection as it seals the area it's tightening due to them being made from rubber
mycrors7 is offline   Reply With Quote
Old 09-21-2022, 07:57 PM   #42
soundman98
soundman98's Avatar
theoretically.
all my wellnuts get more cracked and wrinkled than a 70+ nude beach...
WTB: Blown Front OEM Shocks (SC) WolfSongX Want-To-Buy Requests 8 05-25-2013 06:06 PM
APR Carbon Fiber Front Wind Splitter now available GuerillaRacing Exterior Parts - The Rest 65 03-27-2013 12:36 PM
In the wind? joesem Scion FR-S / Toyota 86 GT86 General Forum 27 01-31-2013 10:09 AM
Wind damaged BRZ's thermobox Scion FR-S / Toyota 86 GT86 General Forum 2 08-24-2012 05:23 PM
