Old 09-19-2022, 04:32 PM   #1
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
Electrical Issue
2013 Frs Manual:
Car will not start: Radio will not work, OBD port will not work
Dash: Has the Car and Lock (prior to key), Door open Icon also on (THAT IS IT)
-Replaced battery
-Checked fuses-21,24,30,45, (all good, and not burned out)
So I just had the entire rear end done, the shop failed to put in a screw for the wheel speed sensor, and it popped out. They also did not do alignment and the car shook at speeds of 70mph. Fixed both issues, and ran the Vishnu tablet to read all codes and eliminate the PO500 code.
PROBLEM: Left the tablet in and it drained the battery. So I replaced it, time for a new one anyway. Replaced sat in the car to see if all is well, and car will not start. So here I am, need your help, ran into a wall.
Fa20Toybaru is offline   Reply With Quote
Old 09-19-2022, 05:59 PM   #2
Fa20Toybaru
FA20ToyBaru
Drives: Manual
Electrical Troubleshooting
2013 Frs Manual:
-Replaced battery
Old 09-19-2022, 06:00 PM   #3
Fa20Toybaru
FA20ToyBaru
Drives: Manual
Car wont start
2013 Frs Manual:
-Replaced battery
Old 09-19-2022, 06:54 PM   #4
So what are the voltage and amperage of the new battery?
Old 09-19-2022, 07:25 PM   #5
Step 1. Don't be a tool. One thread is plenty.
https://www.ft86club.com/forums/show...15#post3547915
NoHaveMSG (09-19-2022), soundman98 (09-20-2022)
Old 09-19-2022, 07:28 PM   #6
Step 2. At least post a video of trying to start it. What do you mean "it won't start?" There are a bazillion ways it won't start. Is it the same with the new battery? Lights? Clicks? Crank?
soundman98 (09-20-2022), x808drifter (09-20-2022)
Old 09-20-2022, 01:01 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you got the right key? is the car in park?
Old 09-20-2022, 01:01 AM   #8
soundman98
soundman98's Avatar
Old 09-20-2022, 08:20 AM   #9
https://www.ft86club.com/forums/showthread.php?t=151141
Old 09-20-2022, 08:20 AM   #10
Old 09-20-2022, 02:27 PM   #11
Grady
Grady's Avatar
Well that is all over the place. Sounds like you are going to ACC or Run? With the tablet plugged in the OBD did you brick the ECU? I did not run what fuses you went through but I would go back and check them all. Not visually with a VOM. From there you will have to start testing where you have power and were you do not.
Old 09-20-2022, 03:45 PM   #12
Rest of the story https://www.ft86club.com/forums/showthread.php?t=151141
Grady (09-21-2022)
Old 09-20-2022, 09:51 PM   #13
soundman98
soundman98's Avatar
i hear carvana gives money for problems.
Old 09-20-2022, 10:01 PM   #14
soundman98
soundman98's Avatar
thanks paul harvey!
Strange electrical issue Sniepster Issues | Warranty | Recalls / TSB 14 11-20-2020 10:54 AM
Complex BRZ Electrical/ECU Issue -- Need help! mackemode Issues | Warranty | Recalls / TSB 14 07-09-2020 12:45 PM
Any mechanic to help troubleshoot electrical issue? DarkSideFRS Southern California 15 04-10-2019 01:53 AM
Electrical Issue TeamJacobs111711 Issues | Warranty | Recalls / TSB 15 08-06-2018 02:41 PM
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 03:09 PM
