Southern California SoCal
Old 04-02-2019, 12:27 PM   #1
DarkSideFRS
Drives: 2013 pearl white FR-S
Any mechanic to help troubleshoot electrical issue?
Anyone on here know how to troubleshoot electrical issues on a mazda? Got a P0328 (knock sensor 1 circuit high input) after replacing my spark plugs, but CEL still there after i switched them back to the original ones. OR any shop recommendation? Went to one near my house and they couldn't figure it out...
DarkSideFRS is offline   Reply With Quote
Old 04-02-2019, 12:34 PM   #2
humfrz
What year, make and model of Mazda?
How is the car reacting (other than giving you a code)?
Have you tried disconnecting the negative side of the battery, then stepping on the break, then reconnecting the battery, to see if the code will go (and stay) away?
humfrz
Old 04-02-2019, 12:36 PM   #3
DarkSideFRS
humfrz
2011 mazda 2... CEL will not go away... tried disconnecting the battery and clearing it via OBD2 reader... cars sounds and idles fine, but drives in limp mode aka less power
The Following User Says Thank You to DarkSideFRS For This Useful Post:
humfrz (04-02-2019)
Old 04-02-2019, 12:45 PM   #4
humfrz
hmmm - have you tried asking over on the Mazda forum?
It may be time for a trip to the shop -
humfrz
Old 04-02-2019, 12:54 PM   #5
DarkSideFRS
humfrz
i went to a shop near my place, and they couldn't figure it out.... mazda forums are very dead, and not very technical
Old 04-02-2019, 02:06 PM   #6
humfrz
OK. You might test/replace (or have done) the knock sensor itself.
humfrz
Old 04-02-2019, 02:17 PM   #7
If the engine is obviously not knocking and all the wires and connections look good then like Hum said it is time to try a new sensor.
Old 04-02-2019, 03:36 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
First off, it's not the plugs.
I suspect that while working on the engine, you may have accidentally damaged the knock sensor connector or wiring. "sensor high" is either an open, or short depending on the design of the system itself. Usually it means "open" (disconnected, burned out, wire cut...)
Find the sensor itself and then consider how the wiring may have been damaged.
If I was the shop, at a minimum, I'd plug in a known good sensor and fire up the engine. If it doesn't throw a code then the sensor went south. If it does, then it's the wiring. Buy a new sensor and be prepared to eat the cost. It's still cheaper than an oscilloscope.
Old 04-02-2019, 04:26 PM   #9
DarkSideFRS
correct, i just swapped the old plugs back in for troubleshooting purposes... the knock sensor is not known to go bad at 60K miles...and it just go happens that it happened after i did the spark plug change... the knock sensor is connected to the PCM which sits on top of manifold... i had to push that aside when doing the spark plugs, but there was enough slack in the wire... if it is the actual wiring to the PCM, i wouldn't even know how to troubleshoot it...
Old 04-02-2019, 09:02 PM   #10
Ultramaroon
not playing cards
look there. Busted wire... loose connector... You're going to need a multimeter to do some continuity checks. If this is Greek to you then don't even start. Take it to a better shop and start by giving them the whole back story.
Old 04-02-2019, 09:55 PM   #11
DarkSideFRS
it's pretty much greek to me haha... even the first shop i brought the car to didn't know how to do electrical work....
Ultramaroon (04-02-2019)
Old 04-09-2019, 05:24 PM   #12
Smaay
Drives: 2013 FRS
wires can look just fine, but somewhere in the loom is a break. have you tried a continnuity check from the sensor to the ECU?
Smaay is offline   Reply With Quote
Old 04-09-2019, 05:33 PM   #13
DarkSideFRS
Originally Posted by Smaay View Post
wires can look just fine, but somewhere in the loob is a break. have you tried a continnuity check from the sensor to the ECU?
i am a total noob when it comes to electrical lol
found a shop... charged me $180 to troubleshoot and fix the issue
Old 04-09-2019, 05:38 PM   #14
Smaay
Drives: 2013 FRS
well, what was the problem?
Electrical Issue TeamJacobs111711 Issues | Warranty | Recalls / TSB 15 08-06-2018 01:41 PM
turbo troubleshoot. yo.dur Forced Induction 9 05-06-2018 12:36 PM
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 02:09 PM
Wierd Electrical issue - no windows + no trunk after battery replacement Takumi788 Issues | Warranty | Recalls / TSB 7 11-11-2016 10:15 AM
electrical issue? unichip and left led fog light not playing nice tracerit Software Tuning 2 10-07-2013 09:09 AM
