| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ
Thoughts On Brake Booster Delete For My BRZ
Hey All,
So I am on a quest to reconstruct my wiring harness, and in doing so, found out that Subaru thought it would be a good idea to bird nest every fucking connection possible into 1 harness. I am doing my own racing harness with TXL wire, Raychem loom, etc, and all while going about this project, noticed the wiring is behind the brake booster, attached to the brake lines, and is a pain in the ass to remove without removing those lines and/or booster. Having said that, I figured that if I'm going to go that far, this might be a good opportunity to install a Chasebays dual-piston brake booster delete. Not sure if anyone here has done such a thing, if so, I'd love to hear your feedback. For everyone else, I'd like to hear your thoughts and/or suggestions as well. Thanks in advance! https://www.chasebays.com/products/c...41700242849961 V/R, Ace IG - Ace23_BRZ |
#2 |
LoL, so yeah, I went ahead and purchased everything...
What will happen to the VDC control module now that I dont need it for the brake lines? Like, do I just plug the brakeline connectors up and plug the harness clip back in and throw it in my glove box now? LoL Any info would be greatly appreicated! Thanks! |
#3 |
Drives: Crapcan
What are you doing with the car? If you can live without ABS go for it
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ace23_BRZ (09-06-2022) |
#4 | |
I've put a lot of blood, sweat, and tears into this build, but most of all, money! haha My ultimate goal would be SEMA. I know that sounds far-fetched, but dreams are achievable. A funny thing just happened as I just got off the phone with my buddy/tuner, and I advised him that I went ahead and purchased the Chase Bay's dual caliper delete kit, and he was like, "Oh yeah, I was going to mention that!" So not sure if that was a universal sign, but I'll take it. He basically stated keep the brain, relocate it. So I'll just go ahead and plug the brake line holes with filler head studs, lengthen the wires a bit, and tuck the VDC module somewhere out of sight and out of mind. |
#5 |
Drives: Scion FR-S 10 Series
I have been looking at the booster delete and chase bays say that you can retain abs. Just fyi incase you want abs for streetability.
#6 | |
Drives: Crapcan
I was just thinking about that being a possibility since the pump is what does the abs work.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Jdmjunkie (09-07-2022) |
#7 |
LMGTFY
Drives: 13 FRS, 91 Miata
No booster no power brakes ABS is an after thought.
#8 |
Drives: None
What do you mean? The booster doesn't drive ABS. This is easily tested by unhooking the vac line from the booster and finding that ABS still works.
In either case, if you're driving this car you're going to want to maintain the booster and ABS. This is a holy war topic in a lot of places on the internet, much like oil or brake pads.
#9 |
LMGTFY
#10 |
Drives: None
That is some odd word choice in this context, but hey, you do you, I apologize for misinterpreting.
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | SuperTom (05-04-2025), x808drifter (09-07-2022) |
#11 | |
ProCrastinationConsultant
i'm reading this thread to try to better understand. i read the whole 'ad' of the chasebay's manual master cylinder. now the opposing side. why would i want to maintain the booster?
#12 | |
LMGTFY
Apparently it's highly dependent on knowing how a cars brakes work. |
#13 |
And oh, BTW, here is my project build thread...if anyone is interested?
https://www.ft86club.com/forums/showthread.php?t=151002 |
| The Following 2 Users Say Thank You to Ace23_BRZ For This Useful Post: | RedReplicant (09-08-2022), soundman98 (09-08-2022) |
#14 |
Drives: 18 Brz (Sold) / 22 BRZ
Booster will provide vacuum assistance to reduce pedal effort, if you build the same pressures, this would not affect the upcoming systems. Be sure to build new lines with similar route as the original. Do not change the abs unit location.
If the dual piston master cylinder has any adjustability, this would crash with the ebd logic from the abs unit. |
| The Following User Says Thank You to Stonehorsw For This Useful Post: | Ace23_BRZ (09-09-2022) |
| FS: OEM Brake Booster Master Cylinder (MT) | MicheleAbbate | Brakes, Suspension, Chassis | 17 | 05-14-2020 04:36 PM |
| Automatic Brake Booster Vacuum Question | spagti | Forced Induction | 0 | 03-15-2019 02:09 PM |
| Brake booster hose missing? | ldam | Engine, Exhaust, Transmission | 3 | 02-28-2019 09:12 AM |
| Metalic clunk from brake booster | 73TORANA! | Issues | Warranty | Recalls / TSB | 0 | 07-20-2014 09:14 PM |
| Checkvalve between brake booster and intake? | Silverdub | Forced Induction | 1 | 09-26-2012 07:50 AM |
