| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#1135 | |
Drives: Q5 + BRZ + M796
Well, if we were dumping 1000x the amount of GHGs and the temperature was going up 5 degrees each year then that might shorten your timeline, but for you, the changes are too slow and the GHGs are too few to matter on a 150 year timeline. Okay, then just say that and begone with the debate instead of stringing everyone along on a pointless exercise with no end in sight. This is why Spuds was trying to tease out your standards and why asked what was your timeline for your long-term criteria because we both knew that we would be wasting our time with pointless errands fetching data when the data doesn't exist because the event has been too brief for your criteria. The last time the CO2 was 420+ppm, the world was 8-10+ degrees F warmer than it is today. At 1000ppm, the earth was 25+ degrees warmer. That is the average, and the extremes are worse. Maybe rising CO2 now won't cause the same temperature that correlated to the CO2 in the past, which is probably why the models are more conservative with their temperature estimates. Regardless, most people don't want to wait around to see what happens when CO2 levels get to 500+ and take a chance with what the temperature could be like. We use to add 1ppm/year, but it is at 2.37ppm/year. That rate is rising too. Even if the rate stayed flat, in fifty years we would be around 550ppm. In 200 years we would be at 1000ppm, assuming this didn't kick off a feedforward effect.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | ZDan (08-30-2022) |
#1136 | |
Drives: _
Cherry picking... like selecting only the convenient 150-160 year window while the rest of it disproves the author? The minute you say an author is a denialist quack, it immediately shows a prejudice and bias. You're putting everyone who disagrees with you under an umbrella term, and categorically rejecting everything they say. And somehow you claim that you're unbiased? Last edited by chipmunk; 08-30-2022 at 06:36 PM. |
#1137 | |
Drives: _
Why is the present CO2 not causing the same temp rise as in the past, despite the depletion of O3 and elevated Methane levels? |
#1138 |
Drives: _
Your own link that says causation is true in the last 150+ years is the same one that says it's opposite overall. Somehow the temperature causes CO2 increase in the 100s of 1000s of years, but yet it contradicts itself within the last 150+?? Something is off - either the test methodology, or inferences.
#1139 | |
![]() ![]() https://www.carbonbrief.org/factchec...limate-change/
#1140 | |||
Drives: '23 BRZ
I am certainly not *discarding* data from other eras! Of course they provide great *context* for what is happening now. Quote:
| The Following User Says Thank You to ZDan For This Useful Post: | Irace86.2.0 (08-30-2022) |
#1141 |
Drives: _
Global averages.
#1142 | |
Drives: _
Seriously, where is your data from? |
#1143 | |
The Dictater
Drives: '13 Red Scion FRS
However, the data shows that within the last few hundred years we are currently experiencing an event where the 'dry' greenhouse gasses (CO2 and CH4) are going through the roof without temperature preceding it. I believe we all agree on that as well? So the question is 'why has the pattern changed'. What makes the last few hundred years different than the last half-million? As you said, any other 160 year period would show different results than the last 160 years. Why do you think that is? What prediction can you make about the next 160 years from this data? 1000 years? |
| The Following User Says Thank You to Spuds For This Useful Post: | Irace86.2.0 (08-30-2022) |
#1144 |
The Dictater
#1145 | |||
https://www.newswise.com/factcheck/r...icle_id=772662 The paper I cited goes through the challenge of making a causal argument, which is why they said: Quote:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4761980/
#1146 |
The Dictater
#1147 |
Right. Do you see the end of this? Very stable, right? Do you think it is a coincidence that humans were able to flourish during the period of climate stabilization, no longer needing to migrate to find food and having the ability to create civilizations with predictable stock yields from farming? Much of earth's history is utterly inhospitable to the type of lifestyle that we know it today. The subsequent highs of CO2 and associated rising temperatures would require dramatic changes.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | ZDan (08-31-2022) |
#1148 | |
Drives: _
We are all in agreement that emissions have gone up, especially CO2 and CH4. The fact that the temperatures didn't follow them should make anyone question if something is missing in the equation. Right now we're debating over a 1 deg C rise in EPICA measurements over the average, but there were times when the temperatures were higher at much lower CO2 levels. Given how little CO2 is in the atmosphere, these correlations makes no sense. I'm gonna venture out on a limb here and make a conjecture - there is some element that has a larger effect. Probably water vapor? I don't know! But looking at CO2 as the only demon has very little data to support. If people want to reduce pollutants like CO, NOx, etc., then yes, by all means! But even if we reduce CO2 to zero tonight, there's no guarantee that this would result in any change in temperatures. |
| Tcoat banned? | Hotrodheart | Off-Topic Lounge [WARNING: NO POLITICS] | 95 | 07-06-2019 01:46 AM |
| Does anyone know why pansontw got banned? | Soloside | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 10-26-2018 04:20 AM |
| Got banned from gf's complex | jdmblood | Other Vehicles & General Automotive Discussions | 11 | 07-12-2015 12:46 PM |
| Why have so many users been banned? | xuimod | Site Announcements / Questions / Issues | 9 | 03-08-2015 02:23 PM |
| Banned Toyota GT 86 Advert Banned | Nevermore | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 11-16-2012 07:27 PM |
