| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
School me on Battery tenders
So now my car is only driven on track it will sit in my driveway for periods with out drives. I will start it and let it warm up one week for 15-20 mins.
Will battery tenders keep the voltage full on the battery or will they only kick in when the battery drops below X volts. I have a small 6lb AGM style battery so it does not have alot of juice. I don't want it to die but I want to understand how this will work.
2013 Series 10 FRS #553
#2 |
Drives: 2012 Toyota 86 GT
Battery tenders have a 'float' mode, where they will first charge the battery up to full and then "pulse" charge it - it lets the voltage decay for a bit, before then charging it back up. This can vary in time, from milliseconds to minutes.
As I understand it, with modern chargers/tenders it's literally as simple as hooking it up and forgetting about it. The battery will stay charged for the length of its normal life. I've had two CTEK models, and the second one doesn't even have an 'AGM' option on the car/motorcycle select button anymore, as it auto-detects whether the battery is lead-acid, calcium, or AGM. Cannot be used on lithium tho iirc. |
| The Following User Says Thank You to euniqe For This Useful Post: | Dadhawk (08-30-2022) |
#3 |
Famous Potatoes
Drives: '15 ultramarine
Get any modern maintainer around 1 to 1.5 amps and you will be fine in California. Keep plugged in at all times with a tiny battery.
My .95 and 1.5 tenders have AGM settings. They are Duracell. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Dadhawk (08-30-2022) |
#4 |
Use this for a truck I only drive every 2-3 weeks, have the clamps run straight to the battery and haven't had an issue in almost a year since I added it. Can't speak to what kind of voltage it's actually putting out but wouldn't imagine it's adding enough juice to be a problem and doesn't need to be plugged in so no cords all over the place.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
#5 |
An option that is rarely discussed is solar.
If the car is outside then it is a very efficient system. I use one on the boat and it has never let me down. https://www.amazon.ca/Maintainer-Wat...555637262&th=1 This looks like a bot response!
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (08-30-2022), flippy (09-08-2022), soundman98 (08-30-2022), Wally86 (08-31-2022), zc06_kisstherain (09-04-2022) |
#6 | |
Drives: 2018 BRZ
| The Following 7 Users Say Thank You to Ohio Enthusiast For This Useful Post: | Dadhawk (08-30-2022), flippy (09-08-2022), soundman98 (08-30-2022), Tcoat (08-30-2022), Ultramaroon (08-30-2022), Wally86 (08-31-2022), x808drifter (08-31-2022) |
#7 |
Go to your battery specifications. It will tell you max charge voltage and recommended float voltage. Then find a charger that falls into those specifications. It is best to get a charger that has temperature compensation. I have always had good luck with Battery Minders. They cost more but also help reduce battery sufidation.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | Flarpswitch (08-30-2022), Ultramaroon (08-30-2022) |
#8 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I've had my motorcycle batteries (similar size) on chargers since '05.
AGM have been fine with Battery Tender units. You can buy extra SAE pigtails to attach to any 12v battery in your fleet to plug the tender into. I put one on my 86 and needed it once when the keyfob opened the trunk overnight when I wasn't looking. If you go with Lithium batteries the chargers need some extra computery stuff in the box but those work too.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Wally86 (08-31-2022) |
#9 | |
Drives: 17 Asphalt 86
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | soundman98 (08-30-2022), Wally86 (08-31-2022) |
#10 |
Drives: ft 86
Is there an article somewhere about how they affect the battery? I am interested in research as usual with graphs and bars. Whenever I think of something, I have to do it. Now I got interested in batteries when I came across this topic. I did not even think before how it all works and what the differences are.
#11 | |
https://batteryuniversity.com/articles |
| The Following User Says Thank You to Grady For This Useful Post: | soundman98 (08-30-2022) |
#12 |
Thanks for the inputs!
Sent from my Pixel 6 using Tapatalk
#13 | |
ProCrastinationConsultant
my experience is that intelligent battery chargers with a 'battery recovery' mode will do a better job at it anyways. *went 7 years on the oem battery alternating between the maintainer for extended parked periods and 2 recovery cycles on the charger near the end of the 7 years.
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (08-31-2022) |
#14 |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | RToyo86 (08-31-2022), soundman98 (08-31-2022) |
| SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray | timepoor | Audio/Visual, Electronics, Infotainment, NAV | 4 | 10-06-2021 10:40 PM |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 12:55 PM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
| Ridge Racing School; Lapping/school Sept 7th | rice_classic | Northwest | 4 | 09-05-2012 01:27 AM |
