Old 08-29-2022, 11:23 PM   #1
jflogerzi
jflogerzi's Avatar
School me on Battery tenders
So now my car is only driven on track it will sit in my driveway for periods with out drives. I will start it and let it warm up one week for 15-20 mins.
Will battery tenders keep the voltage full on the battery or will they only kick in when the battery drops below X volts. I have a small 6lb AGM style battery so it does not have alot of juice. I don't want it to die but I want to understand how this will work.
2013 Series 10 FRS #553
Old 08-30-2022, 12:17 AM   #2
euniqe
euniqe's Avatar
Drives: 2012 Toyota 86 GT
Battery tenders have a 'float' mode, where they will first charge the battery up to full and then "pulse" charge it - it lets the voltage decay for a bit, before then charging it back up. This can vary in time, from milliseconds to minutes.
As I understand it, with modern chargers/tenders it's literally as simple as hooking it up and forgetting about it. The battery will stay charged for the length of its normal life.
I've had two CTEK models, and the second one doesn't even have an 'AGM' option on the car/motorcycle select button anymore, as it auto-detects whether the battery is lead-acid, calcium, or AGM. Cannot be used on lithium tho iirc.
euniqe is offline   Reply With Quote
The Following User Says Thank You to euniqe For This Useful Post:
Dadhawk (08-30-2022)
Old 08-30-2022, 12:32 AM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Get any modern maintainer around 1 to 1.5 amps and you will be fine in California. Keep plugged in at all times with a tiny battery.
My .95 and 1.5 tenders have AGM settings. They are Duracell.
Old 08-30-2022, 08:06 AM   #4
ThatYeti
Use this for a truck I only drive every 2-3 weeks, have the clamps run straight to the battery and haven't had an issue in almost a year since I added it. Can't speak to what kind of voltage it's actually putting out but wouldn't imagine it's adding enough juice to be a problem and doesn't need to be plugged in so no cords all over the place.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
ThatYeti is offline   Reply With Quote
Old 08-30-2022, 08:24 AM   #5
An option that is rarely discussed is solar.
If the car is outside then it is a very efficient system.
I use one on the boat and it has never let me down.
https://www.amazon.ca/Maintainer-Wat...555637262&th=1
This looks like a bot response!
Dadhawk (08-30-2022), flippy (09-08-2022), soundman98 (08-31-2022), Wally86 (08-31-2022), zc06_kisstherain (09-04-2022)
Old 08-30-2022, 08:59 AM   #6
Ohio Enthusiast
Drives: 2018 BRZ
Reported!
The Following 7 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Dadhawk (08-30-2022), flippy (09-08-2022), soundman98 (08-31-2022), Tcoat (08-30-2022), Ultramaroon (08-30-2022), Wally86 (08-31-2022), x808drifter (08-31-2022)
Old 08-30-2022, 09:34 AM   #7
Grady
Grady's Avatar
Go to your battery specifications. It will tell you max charge voltage and recommended float voltage. Then find a charger that falls into those specifications. It is best to get a charger that has temperature compensation. I have always had good luck with Battery Minders. They cost more but also help reduce battery sufidation.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Flarpswitch (08-30-2022), Ultramaroon (08-30-2022)
Old 08-30-2022, 01:27 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I've had my motorcycle batteries (similar size) on chargers since '05.
AGM have been fine with Battery Tender units.
You can buy extra SAE pigtails to attach to any 12v battery in your fleet to plug the tender into.
I put one on my 86 and needed it once when the keyfob opened the trunk overnight when I wasn't looking.
If you go with Lithium batteries the chargers need some extra computery stuff in the box but those work too.
Old 08-30-2022, 01:33 PM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Good bot
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Old 08-30-2022, 06:01 PM   #10
Gialren
Gialren's Avatar
Drives: ft 86
Is there an article somewhere about how they affect the battery? I am interested in research as usual with graphs and bars. Whenever I think of something, I have to do it. Now I got interested in batteries when I came across this topic. I did not even think before how it all works and what the differences are.
Gialren is offline   Reply With Quote
Old 08-30-2022, 06:56 PM   #11
Grady
Grady's Avatar
Rabbit hole activate!
https://batteryuniversity.com/articles
The Following User Says Thank You to Grady For This Useful Post:
Old 08-30-2022, 10:57 PM   #12
jflogerzi
jflogerzi's Avatar
Thanks for the inputs!
Sent from my Pixel 6 using Tapatalk
Old 08-31-2022, 12:41 AM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
calcification of the plates does tend to happen as part of any constant charging cycle. many battery maintainers tend to try to abate it a little by introducing an a/c waveform into the charging cycle to 'jiggle' the deposits loose from the plates.
my experience is that intelligent battery chargers with a 'battery recovery' mode will do a better job at it anyways.
*went 7 years on the oem battery alternating between the maintainer for extended parked periods and 2 recovery cycles on the charger near the end of the 7 years.
NoHaveMSG (08-31-2022)
Old 08-31-2022, 08:24 AM   #14
Originally Posted by RToyo86 View Post
Good bot
RToyo86 (08-31-2022), soundman98 (08-31-2022)
SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray timepoor Audio/Visual, Electronics, Infotainment, NAV 4 10-06-2021 11:40 PM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Ridge Racing School; Lapping/school Sept 7th rice_classic Northwest 4 09-05-2012 02:27 AM
