| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#337 |
ProCrastinationConsultant
"it depends"
on who keeps records. who reports the records. who makes those records available to others. and who records/watches for available records. sometimes oil changes are reported. others lose the entire front end while driving through a kindergarten class that makes national news, while it still doesn't end up in any official record. i've seen a number of odometer differences cause red flags over the years i've tried using carfax for vehicle history reports. most of the time, it comes down to some department knucklehead listing a vehicle mileage at 35,050 one year, 38mi/383,490mi the next, and 42,350 the next. my car was listed by dmv/emissions records as a 'ranger' for a year, which, if carfax picks up, ought to be interesting how they handle a vehicle model change partway through it's lifespan... frankly, it doesn't matter to me. i'm keeping the car, and if resale comes to the front of my mind when discussing a car, then it's not a car worth keeping around anyways.
#338 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
I wouldn't even be completely sure that its a process issue, what if the design specified amount and application area for the sealant, or a specific type, and that wasn't correct. Its not like these companies use excess stuff for no reason - money means that its usually that they specify a type or amount that is of the least amount/quality possible. |
#339 | |
Drives: '15 GT86 & '22 GR86
I don't think the issue is positioning, it's likely to be the quantity of the RTV sealant used and the cure time. If the matting surfaces have too much sealant and its still too wet before they are pressed together it will push out the sides. |
#340 | |
The engines are Subaru, designed by Subaru engineers, Made in Subaru plants by Subaru employees. The identification and fix of the ROOT CAUSE is a Subaru issue. This is why what plant is indeed very important. Remember that Toyota buys these cars from Subaru. They are customers just like you. You counter your own statement at the end there. If they designed it for a certain amount and that amount is not what is there then it is a process issue.
#341 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#342 | |
It is simply the difference between market and actual value of a car that has been repaired due to an accident. Even then there are very specific requirements as to who and what caused the accident and can only be claimed if you are not at fault. Replacement of a blown engine either through warranty or privately is not an accident. So... unless your damage is caused by an accident with blame on somebody else there is simply no way to claim diminished value.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (08-03-2022), soundman98 (08-03-2022) |
#343 | |
Drives: '23 BRZ Limited
This person is obviously not familiar with "manufacturing engineering."
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#344 |
Over the years he has proven to be unfamiliar with many things but still has strong opinions on them.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | OkieSnuffBox (08-03-2022), Ultramaroon (08-03-2022) |
#345 | |
Drives: Crapcan
Changing the argument is not a valid tactic. The specified sealant, amount, and application area is very well known and understood since it has been in use for a decade on the same family of engines. If that was the issue we would be seeing it on a lot more engines now wouldn’t we?
#346 |
Drives: 2022 BRZ sport-tech
LOL....the internet is certainly having some fun about this.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
| The Following 2 Users Say Thank You to Petah78 For This Useful Post: | NoHaveMSG (08-03-2022), soundman98 (08-03-2022) |
#347 |
Drives: '12 C63 P31, '23 GRC
Oil pressure switches (as found on many vehicles) are 100% worthless. My Cayman had an oil pressure switch, and was good enough to tell me I had zero oil pressure when I tried to restart the engine, AFTER I had already lost the #6 cylinder rod bearings from oil starvation. It's basically a feature to tell you you're already f*cked.
If someone intends to track their car on a regular basis, I would highly recommend installation of an oil pressure sensor and real time display gauge.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#348 | |
Drives: '22 BRZ
Correct, it MAY have caused damage. If Subaru/Toyota are smart they won't take that risk and they'll replace the engine in entirety.
#349 | ||
Drives: '22 BRZ
Sure it's still getting flow from the other 4 sides but it's not getting *proper* flow. This is a fairly basic engineering problem and anyone that's saying the RTV isn't causing the issue is simply not understanding how much little things matter. If Subaru/Toyota thought they didn't need that side of the box to be open, they'd have left it closed.
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#350 |
Drives: 1996 Turbo Miata
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
