timurrrr
Old 08-02-2022, 04:14 PM   #309
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
Actually if the issue is appearing with the timing chain cover that can also be the difference. The oil pan is the same across them all but the timing cover is not.
Good to see you still active just like 2014. if this continues I recon ppl gonna start a religion after you.
PS: I was right about never getting 1st year Subarussss, I'm gonna wait till model refresh this time cuz I still had to redo my timing chain cover due to leak on my 2015. *just dropping by cuz i saw it on the news.
The Following User Says Thank You to chaoskaze For This Useful Post:
strat61caster (08-02-2022)
Old 08-02-2022, 04:32 PM   #310
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by DocWalt View Post
The problem is with the RTV on the pickup and starving the engine of oil, it's already done damage to the bearings and oil pump. Sure you can remove the RTV but you can't remove the damage.
I disagree with this...and until proven otherwise this entire "loose sealant blocked the oil screen" thought process.
On the new 2.4 engine, the pick up uses a 5 sided screenbox to ensure proper oil flow in case of a partial blockedge. You can see it in the pictures floating around...it's a box with sealant at the top, but the other 4 sides of passages are open and clean. Unlike the previous version pickup that had a circular screen at the bottom that could be completely clogged. The little bit of blockage shown, while not ideal, would not grenade an engine and would maintain proper oil pressure.
I'd bet there is something else "starving" the oil on the cars that have failed. Maybe oil not returning to the pan in high g loads, (ie; drifting, hard corners), maybe low factory oil fills, maybe faulty PVC systems, maybe faulty new oil pumps.......
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
chaoskaze (08-02-2022), raisingAnarchy (08-02-2022), villainous_frx (08-02-2022)
Old 08-02-2022, 04:56 PM   #311
ninjan00dles
Drives: 2015 FRS
Cavitation due to inlet blockage... you have to take into account mass flow rate, fluid velocity as the suction inlet shrinks, oil pump speed /rpm and a few other things. If you have a blockage the fluid velocity has to increase to maintain the same mass flow rate which lowers your pressure, look at bernoulli's law. Even if it's not completely blocked, at sustained high RPM with all those factors that's enough to give you enough starvation to spin your bearings.
There was a guy who tracked extensively /owned a shop in South America (Peru?) on this forum who was blowing 13-16 motors left and right until he went to a larger pickup tube. The thread should be on this site, he had some good data points.
ninjan00dles is offline   Reply With Quote
The Following 5 Users Say Thank You to ninjan00dles For This Useful Post:
DocWalt (08-03-2022), DylanJZA (08-03-2022), Dylans47 (08-02-2022), NoHaveMSG (08-02-2022), OkieSnuffBox (08-02-2022)
Old 08-02-2022, 05:04 PM   #312
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by LRNAD90 View Post
First Gen had the Valve Spring issue, Second Gen this Sealant Issue. First Model years are scary, even for Japanese Engineered AND Built vehicles it seems..
There was also the bad tune not fixed for the first year of production that under fast shifting would knock, burn up the direct injector seals, go lean, and blow the engine.
https://www.ft86club.com/forums/showthread.php?t=36008
Throwout bearings blew up:
https://www.ft86club.com/forums/showthread.php?t=96644
Coil packs failed:
https://www.ft86club.com/forums/showthread.php?t=112218
Oiling issues and spun bearings:
https://www.ft86club.com/forums/showthread.php?t=107959
Fuel starving:
https://www.ft86club.com/forums/showthread.php?t=118973
Broken axles: (autocrossers will literally carry spare axles to big events)
https://www.ft86club.com/forums/showthread.php?t=49511
And a host of oil leaks:
https://www.ft86club.com/forums/showthread.php?t=67454
These cars have never been bulletproof and it seems memory is short on the first gen issues that didn't really get cleaned up until 2015 or so. Even then you can still fuel/oil starve any FA20 FRZ86 unless you put some mods in, or break an axle. And I suspect those particular issues will persist in the 2nd gen because fixing those issues would add hundreds if not thousands to the sticker and 99% of these cars will be driven no harder then grandma's Prius while under warranty.
If you want to drive a sports car at 10/10ths and not have the manufacturer deny warranty claims I'd get a Porsche, Mazda, or BMW/Mini over anything else, and even then they still might tell you to go pound sand. (I know a guy who put 4 transmissions in his ND Miata, Mazda warrantied the first 2 or 3 iirc)
If I had a new car I'd be pulling the oil pan this weekend, cleaning out the tube and applying new sealant. I'd repeat at the next oil change and cross my fingers that's that and no more would break off the timing chain cover. This is one of the easiest to prevent issues this chassis has had and it's a one time fix.
*as my fucking 2nd TOB starts making noise at 115k miles*
ineedyourdiddly
Old 08-02-2022, 05:10 PM   #313
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Possible. But they are also towing and being pushed hard in other ways.
Just tracking should not be a reason. Will have to see if there are many that were not tracked.
Curious if more cases of blown motors starts popping up as more cars hit 10-15k on the odo. Has anyone found rtv in the filters?
Someone on the FB group checked their dipstick.
Robertw is offline   Reply With Quote
Old 08-02-2022, 05:27 PM   #314
chipmunk
Drives: _
Is that RTV on the dipstick fully bonded on the tip? Or is it just sitting there?
chipmunk is offline   Reply With Quote
Old 08-02-2022, 05:49 PM   #315
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Chev View Post
Toyota Brand Engagement Center (1-800-331-4331)
I suggest everyone call. Let these guys know we have a voice and will use it.
I called them on my way to work.
Shared my buying experience, complained at the dealerships that sucked, and praised the dealership that got me the car.
Told them I saw the news on Road & Track and CarBuzz about people who got warranty denied after a track day, and got worried given that I'm offered a free NASA track day.
Told them they I like the car and appreciate that Toyota makes them, but that the dealership experience very negatively impacted how I see Toyota as a brand, and how my friends see it.
The guy on the phone listened and "took down every word and will escalate", apologized for the experience at the end, and overall acted like he cares. I felt like I was doing a confession for someone else's sins haha.
A note of warning: they asked for my full name and VIN number. I said I was driving (I was!) and didn't have the VIN handy. I wonder how many John Does are going to call them
Give them a call. A sudden influx of people all bringing up the same / similar topics will not hurt, and there's a slight chance Toyota is going to listen and change their stance. They put so much great effort into marketing the GR86 it would be a shame if another department(s) blow it up.
If you're busy and don't want to waste too much time, call them on the way to work.
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
itschris (08-02-2022)
Old 08-02-2022, 06:06 PM   #316
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
The Drive has now reported this too.
https://www.thedrive.com/news/toyota...as-not-talking
spcmafia is offline   Reply With Quote
Old 08-02-2022, 06:07 PM   #317
Rainy
Rainy's Avatar
Drives: 2015 Brz
just saw someone drop the oil pan on Facebook with short video, he also see RTV in oil pickup
https://www.facebook.com/MNIVETMX5/p...Tr8RWDfRJ3DGol
Rainy is offline   Reply With Quote
Old 08-02-2022, 06:30 PM   #318
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So much for 2nd Gen Master Race lol
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 08-02-2022, 06:44 PM   #319
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
My, uh, dipstick is clean. Don't know about the rest of the pan though
Old 08-02-2022, 06:47 PM   #320
otter
Drives: 22 BRZ
I haven't had time to pull my own oil pan yet but something that's stood out to me as I see everyone's pictures - there appears to be very little surface area on the engine side of the mating surface. I've never worked on a Subaru engine but for other engines I've pulled pans on there would usually be about 3/4" of mating surface but some of these pictures look like they're only 1/2", if not less. I could be wrong though since it can be hard to tell scale in pictures without a banana. That narrow surface would make it super easy to over-apply.
otter is offline   Reply With Quote
Old 08-02-2022, 07:01 PM   #321
Lantanafrs2
Drives: 2013 frs red
https://www.roadandtrack.com/news/a4...repair-denied/
Lantanafrs2 is offline   Reply With Quote
Old 08-02-2022, 07:20 PM   #322
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
I disassembled my filter today and there was nothing notable in there. 2 tiny metal shavings, a few tiny black particles, and a small piece of light green somethingorother.
removedonut is offline   Reply With Quote
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
