| Member's Car Journals Car journals by our members. |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
'23 BRZ Manual Track Build
After pretty much receiving all the parts but the car itself, I've finally picked up my Gray '23 BRZ Premium, yesterday
![]() I love keeping journals of track builds, so I decided to start this one. This car will join my '19 Corvette Z06/Z07 M7 as second track car: https://www.corvetteforum.com/forums...ld-thread.html
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
| The Following 4 Users Say Thank You to X25 For This Useful Post: |
#2 |
Current pics
9/3/2022; at ORP. 10/13/2022; post coilover install + alignment (12.875" front, 13.125" rear). Stock is about 14.5" front, 14.75" rear.
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) Last edited by X25; 02-21-2023 at 03:28 AM. |
| The Following User Says Thank You to X25 For This Useful Post: | villainous_frx (07-30-2022) |
#3 |
Mods List [Will be kept up-to-date]
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) Last edited by X25; 02-21-2023 at 03:34 AM. |
#4 |
I'm trying to see if I can make it to Aug 12th Oregon Raceway Park ORP-club day event.
The plan OEM-ish baseline:
These should make the car ready for track with no braking issues. After this, I will start adding the remaining mods (most important of which is coilovers of course), and we'll see how the handling and lap times changes : ) Already received almost everything (except the harness bar). AP brakes look good. Opted for the bigger brakes, especially since float design is much more resistant to cracks, etc. Falken RT-660 street tires Yum yum; MCS 2WNR I also plan to test tires' heat cycles with a durometer..
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) Last edited by X25; 07-30-2022 at 03:52 AM. |
| The Following 3 Users Say Thank You to X25 For This Useful Post: |
#5 |
Drives: Crapcan
The surface at ORP is pretty abrasive. I found the RT’s harden 2-3 points after their first cycle but don’t drop off much after that until they cord. The first time I ran them was at ORP. You running CCW or CW at ORP? It’s a really fun track regardless. I prefer the CCW layout a bit more. Something about dropping down from Valkyrie and flicking it into that right hander at the bottom is so satisfying.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | villainous_frx (07-30-2022) |
#6 |
I have no idea what direction they'll run that day, but my lap times are about same both directions anyway. Indeed, the surface has always been one of the most abrasive, and feels like it got even more so in recent years. With my Z06, tires are gone in just a few days (front shoulders cord first).
Checking on hardening on the surface is also a bit tricky. Since tires collect rubber, I'm planning to get measurement from the wear marker holes' inside bottom. We'll see if it makes sense : p
| The Following 2 Users Say Thank You to X25 For This Useful Post: | NoHaveMSG (07-30-2022), villainous_frx (07-30-2022) |
#7 |
Drives: NC Miata (under construction)
#8 |
Hey thanks! Now all you need to do is to get one for yourself, too : )
#9 |
#10 |
Drives: Crapcan
You may not get real consistent results at the wear mark. Usually you want to check on a flat surface if possible. I had some spots I didn’t have pickup that I checked and hit all across the tire. I think I was getting about 72 shore A after the first cycle checked at about 65-70f. I have a cheap gauge but have a 50A standard I checked it with and it was pretty close.
#11 |
On track to getting ready for next weekend! Installed AP brakes, dropped off the OEM wheels for getting RT660s mounted, will install rear UCA tomorrow, and will get the car aligned on Wednesday.
Realized on Saturday that none of my Motive bleeders work. The correct one is 1107. It's a bit finicky, though. Once it starts going down, you should not twist it more than 1/8 turn, or it gets stuck. I had to remove it using plyers during my first trial! Removed the charcoal filter. It's thicker than I thought. I'm guessing these are strap rings used during the transportation of the cars? Anyway, I wonder if I can use them as well on the trailer.. 325mm 2-piece AP rotors are 16.4 lbs. OEM are 17.1 lbs. AP Caliper is 4.9 lbs, pads are 2.3 lbs, mounting hardware per side is 1.4 lbs, and SS lines are 0.2 lbs; 8.8 lbs. OEM calipers with all hardware and lines are 14.4 lbs each. TOTAL system: OEM: 31.5 lbs AP 325mm: 25.2 lbs (6.3 lbs lighter per side) It's a bit hard to see, but Ferodo front pad is at the top, and the OEM pad is at the bottom. Dropping another 1.2 lbs unsprung weight with the dust shield delete (as recommended by AP racing instructions). Finished!!
| The Following 2 Users Say Thank You to X25 For This Useful Post: | gcmak (08-01-2022), villainous_frx (08-01-2022) |
#12 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Nice build!
How do the tires look on OEM wheels?
#13 |
Thanks! The tires are still at the shop; haven't picked them up, yet. I really liked the OEM wheel design, though. It is convex, and provides ample clearance for brakes. Hopefully it will indeed fit AP brakes as was listed on the forum, otherwise I'm in trouble : P
I'll measure the stock ride height as well when it gets the alignment on Wednesday, so they will be my baseline measurements..
#14 |
... and I'm ready for the alignment, and first track day event!!
OEM unmounted tires on the right, and RT660 225/45/17 tires mounted on OEM wheels on the left. It looks pretty flush with OEM wheels and Falken's 225s. Cusco rear UCA on the top of OEM part. 5.3 lbs vs. 8.9 lbs OEM 1.8 lbs vs 2.0 lbs OEM OEM lug nuts, though light, still weigh 1.3 lbs vs. Gorilla at 0.6 lbs. Everything installed! Also checked on the wheel clearance, and it looks good. Why is Subaru painting bolts? Anyway, changed the oil as well (to 5W-30) for track use. Finished! It has zero camber right now, but has huge potential with the changes. I'll be driving to track to add some more miles before the first event, and will be testing it out on Friday; looking forward to it!
| The Following 2 Users Say Thank You to X25 For This Useful Post: | new2subaru (08-13-2022), villainous_frx (08-02-2022) |
| $5K for track build | Kulebrero1 | Tracking / Autocross / HPDE / Drifting | 27 | 05-08-2022 10:51 PM |
| GT86 CS V3 track car manual | ayau | Tracking / Autocross / HPDE / Drifting | 12 | 08-21-2013 12:03 AM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
| Black GTS Manual Nov/Dec build in ACT | FT86RR | Australia Classifieds | 1 | 08-23-2012 11:55 AM |
| 4/30 Build sheets for Manual and Auto FR-s | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 04-30-2012 06:26 PM |
