Old 07-19-2022, 10:57 AM   #57
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Originally Posted by Windycitystig View Post
Which heat reflective tape brand did you use?
/it was just some amazon gold reflective tape. I forget the exact brand.
B T is offline   Reply With Quote
Old 07-25-2022, 04:01 PM   #58
CSG Mike
CSG Mike's Avatar
Originally Posted by SuperTom View Post
Wow I wonder what they changed
They downgraded the design to use cheaper components, pre-bent piping, smaller flanges, etc.
Basically, all of the feedback from CSG that resulted in the Ace header continuing to evolve was mostly undone.
Old header (not the latest/best version) vs current Ace header.
The performance is NOT the same, and very visible on a dyno.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Espi (07-25-2022), Spawn_Of_Creation (07-26-2022), SuperTom (07-26-2022)
Old 07-26-2022, 06:41 AM   #59
Calum
That Guy
Drives: 2013 asphalt FRS MT
Can you show us the difference on a dyno?
The Following 3 Users Say Thank You to Calum For This Useful Post:
DocWalt (08-18-2022), SuperTom (07-26-2022), villainous_frx (07-27-2022)
Old 07-27-2022, 05:17 PM   #60
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Source: trust me bro.
villainous_frx is offline   Reply With Quote
The Following 4 Users Say Thank You to villainous_frx For This Useful Post:
Calum (07-28-2022), DocWalt (08-18-2022), strat61caster (07-29-2022), Ultramaroon (07-27-2022)
Old 07-27-2022, 05:46 PM   #61
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I have reason to trust Mike as CSG is the main US retailer for the ACE headers, as well as all the testing and experience they did with them.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
whataboutbob (07-29-2022)
Old 07-28-2022, 11:10 AM   #62
Swolzee
Swolzee's Avatar
Drives: Honda Insight
I was deciding between the Ace350 and the JDL 4-2-1. Performance wise it's really splitting hairs (that being the old design Ace BTW) so buying a product made in the USA vs one that's not, and saving several hundreds of dollars made the choice easy.
Then again maybe if I was planning on staying NA and really wanted to squeeze every ounce out of the FA20 I would have thought a bit harder about it. Probably come to the same conclusion but it would give me pause
Swolzee is offline   Reply With Quote
Old 07-28-2022, 11:42 AM   #63
CSG Mike
CSG Mike's Avatar
Since someone asked... (this is not my image) This is a later iteration of the A350, but a few revisions before the current.
Old 07-28-2022, 04:26 PM   #64
H1C
Drives: 2014 FR-S MT
I'm looking into replacing my Tomei EL and OP with this one. Ace told me that they have not yet shipped a single unit of this version.
They also told me that stiffer engine mounts and ceramic coating are not needed with this version, but that it may contact the skid plate because of the length of the runners. But the OP should not contact the engine cross member under load/in cornering.
H1C is offline   Reply With Quote
The Following 2 Users Say Thank You to H1C For This Useful Post:
Calum (07-28-2022), villainous_frx (07-28-2022)
Old 07-28-2022, 07:13 PM   #65
Calum
That Guy
I haven't had issues with any of that with my cs400. Just a single data point
The Following User Says Thank You to Calum For This Useful Post:
H1C (07-28-2022)
Old 07-28-2022, 07:19 PM   #66
Calum
That Guy
Yeah, I severely doubt a slight increase in bend radius of one part, and a slightly thinner flang material (reportedly) is showing up on a dyno. The tension of the hold down straps would likely make a bigger difference.
The Following 2 Users Say Thank You to Calum For This Useful Post:
H1C (07-28-2022), villainous_frx (07-28-2022)
Old 07-28-2022, 09:02 PM   #67
H1C
If it's true that Ace hasn't yet shipped one unit of this version, it seems the only way anyone could know how it dynos is if they were privy to the results of pulls that Ace themselves have done with it.
I asked Ace for a dyno plot comparing it to stock, but didn't get a response on that. I'm leaning towards taking a chance on this version, based on previous versions' ability to fill in the torque dip.
I'll report back after I've broken in a tune on it and have had it dyno'd.
Calum (08-02-2022), villainous_frx (07-28-2022)
Old 07-29-2022, 02:46 PM   #68
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Are people still trying to get the ACE exhaust in 2022? It offers similar if worse performance than the JDL unit, with higher chances of cracked welds, you basically need engine mounts with it, and it costs SO SO much more if you can even get one.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 07-29-2022, 11:32 PM   #69
CSG Mike
CSG Mike's Avatar
tl;dr
The "new" A350 is the old "RHD" unit.
Perhaps they haven't shipped it under the new labeling, but I'm an equal opportunity truth dealer, and well.... yeah. These are out there, maybe under the old label.
Old 07-29-2022, 11:46 PM   #70
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
ACE does outperform the JDL.
You don't need better engine mounds with it.
Cost is the reason they stopped supporting twin owners, because most are cheap.
Welds cracking is not unheard of with any other brand.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
villainous_frx (07-29-2022)
ace, ace 350, aceheader
STI Lip Kit Discontinued? ADabOfOppo BRZ First-Gen (2012+) — General Topics 12 10-15-2015 12:08 PM
Top Speed Auto UEL Header Discontinued raven1231 Engine, Exhaust, Transmission 11 09-28-2014 01:42 PM
FR-S / BRZ Discontinued? Thatruth2001 Northwest 16 06-27-2014 04:30 AM
BRZ MIGHT BE DISCONTINUED AFTER ONE GEN?? airjonny BRZ First-Gen (2012+) — General Topics 37 06-24-2014 02:47 PM
openflash header replica? toby714 Engine, Exhaust, Transmission 30 06-05-2014 03:11 AM
