Old 07-21-2022, 05:53 PM   #15
Originally Posted by gpvecchi View Post
Thank you very much for your appreciation! Unluckily Italy is a beautiful place, stuck in bureaucracy and corruption...
Every exhaust has to be ECE approved, so muffler artisans are out of the market...
OK, how about you post a picture(s) of your maligned exhaust -
Maybe we can see a solution -
DarkPira7e (07-21-2022)
Old 07-21-2022, 05:55 PM   #16
Originally Posted by nextcar View Post
But as I recall from all the magnificent statues, one side always hangs a little lower than the other!
I hope this visual aid isn't too on the nose, so to speak.
Old 07-21-2022, 06:53 PM   #17
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
The only way to correct is to bend them, with the risk of snapping them...
Was this in regards to the hangars? maybe I used the wrong term. The rubber piece that attaches the muffler to the car. If it's not centered on the stationary post that's welded to the car it can have this effect. When I first installed my exhaust I had the same thing and I went under and shook things around a bit. Also noticed one of the rubber hangars was not sitting straight and centered across the post. Once I adjusted it it righted itself. A little water with some soap added should loosen it up enough to help it along.
2020BRZtS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
humfrz (07-22-2022), Ultramaroon (07-21-2022)
Old 07-21-2022, 11:13 PM   #18
2020BRZtS
2020BRZtS's Avatar
That picture says a lot. You know they are disabled and how they got that way.
EDIT: Wait, that's a PA tag. Now it makes sense.
EDIT 2: $10 says that's walmart
humfrz (07-22-2022), Ultramaroon (07-22-2022)
Old 07-23-2022, 03:06 PM   #19
gpvecchi
gpvecchi's Avatar
Thanks, unluckily it's difficult to take a straight photo: the left tip leans out 1 cm more than the right one.
The Following User Says Thank You to gpvecchi For This Useful Post:
humfrz (07-25-2022)
Old 07-25-2022, 06:14 PM   #20
Bubba's LAST tip.
Spread a fender cover on the ground along side the offending exhaust piece. Lay down and kick the end of the tail pipe till it looks like the other one.
Decep (07-26-2022), Ultramaroon (07-25-2022)
Old 07-25-2022, 09:02 PM   #21
Bubba's LAST tip.
This is exactly what I have done in the past and would do again if needed. It works.
Well except I just laid on the concrete since I would not want to get a fender cover covered in grit.
humfrz (07-25-2022)
Old 07-26-2022, 12:39 PM   #22
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
My OEM and magnaflow exhausts were like this. My perrin was perfect out of the box.
wolffbite is offline   Reply With Quote
Old 07-26-2022, 01:37 PM   #23
Decep
Drives: 2013 FR-S Series 10
One of my corsa catback tips stuck out a bit further than the other side as well. Loosening the bolts, adjusting it and retightening it fixed it by ~90%
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
CSG Touring86 Competition Catback Exhaust NEW - Track-ready, mature exhaust note ajcarson11 Engine, Exhaust, Bolt-Ons 3 04-29-2018 08:21 PM
Will midpipe from Spec-D Tuning exhaust work on a Megan Racing OE-RS exhaust? neonknight77 Engine, Exhaust, Transmission 13 01-09-2018 06:11 PM
Front Mount Tilted License Plate Bracket Kinzo Exterior Parts (Aero, Lighting, Etc.) 6 11-19-2014 07:59 PM
Another project teaser. Exhaust hole covers for single exit exhaust! Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 57 05-30-2014 02:46 AM
Revive Your Exhaust Tone with Our Debut FT86Club Exhaust Clearance Sale! FRSport.com Engine, Exhaust, Bolt-Ons 0 09-06-2013 03:08 PM
