Found a solution to the P0193 CEL
Long story short, it's the fuel pressure regulator.
I tried researching what the problem was on the forum, but there was no definite answer. I had it towed to Subaru in Scottsdale after my BRZ broke down in the middle of the street and they replaced the battery stating that the HPFP "Wasn't receiving enough voltage". I decided to believe them and the next day my car broke down in the middle of the street again. Subaru said that it might be my mods so I decided not to go to them again. I had it towed to a local tuner shop, where they removed the HPFP and tested the voltage (everything tested OK) and then they put it on the dyno to see where the fuel cut was occurring. They decided it was the fuel pressure regulator. They replaced the regulator and now the car runs great. The other threads say it might be a bad HPFP, ECU, ECM, or IBU...but do yourselves a favor and spend the $100 to get the regulator replaced before you spend thousands on the above-mentioned parts. Just paying it forward! -Steve |
| The Following 10 Users Say Thank You to norcalpb For This Useful Post: | frs23 (07-11-2022), GT86_PRAGUE (06-10-2016), Guff (06-03-2016), H380 (07-17-2022), JohnH (07-19-2022), Spartarus (06-06-2016), Tcoat (06-03-2016), Traffic (06-01-2016), Ultramaroon (07-17-2022), Wally86 (07-18-2022) |
#3 |
Yeah, I figure everyone is pretty low miles still. But once they get closer to 60k this thread will be useful
#4 |
Drives: BRZ DGM Limited
Since the dealer could not find the cause and turned you away, if your car is still under warrantee send a copy of the repair receipt to Subaru Corp Office and ask for your money back. They should honor your request
| The Following User Says Thank You to BRZnut For This Useful Post: | JohnH (07-19-2022) |
#5 |
Got a p0193 this morning, car had been sitting since yesterdays track day. Car took a while to crank over but then fired up with a CEL and traction control light on.
Forums been down all day today so I’ve been eagerly waiting to click on this thread as it seemed OP had it figured out. Turns out I am the OP lmao! Will try to diagnose tomorrow and will provide an update. 169k (nice) miles on the car. |
| The Following User Says Thank You to norcalpb For This Useful Post: | bcj (07-18-2022) |
#6 |
ECU just needed a reset, so weird.
#7 |
I wonder if it was never actually the regulator. Maybe it's an intermittent connection somewhere.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | norcalpb (07-18-2022) |
#8 |
I was thinking the same thing. I wonder if this is a symptom of my BCM being fried after I expertly removed the door lights with a metal screw driver, with the harness still plugged in.
#9 | |
A high pressure signal could be the result of the failed regulator, or it could be a sensor circuit open. If the result of a failed regulator, the pressure sensor MIGHT show a fluctuating reading. Open sensor will show hard high for sure.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | norcalpb (08-03-2022) |
#10 | |
After I got the car back I let it sit which I should not have done as there was no time for the permanent code to clear. I started it up a few days later and bam P0193. However this time I was able to clear it with my open flash tablet. I start driving down the road and the engine shuts off and the CEL comes on. I am able to clear it in the middle of the road before the light goes green and pull into a gas station. The code would come back every time I turn off the car and turn it back again. I decided to randomly reload my stage 2 tune and the code went away and I could drive the car. Next morning same exact thing happens except this time the throttle doesn't work, and I can't clear the code with my OFT. I paid for one month of an app called "Auto doctor" on my phone which I was able to clear the code with. Drove around and the permanent code cleared. I was so excited except the next morning it does it again!! This time I am also getting a P0087 code which means the fuel pressure is low. So, fuel pressure is too high, while also being too low - right... I decide to take off the driver side rail cover to inspect the HPFP and everything looked good. I didn't want to remove anything, so I simply unplugged the fuel pump, cleaned the connector and plugged it back in. Shockingly, the car now runs perfectly. It has started fine the last week straight with no issues. Now I know unplugging the fuel pump probably didn't do anything. My main theory is that I got a bad tank of gas, because now that I have run 1/2 a tank of new gas everything has worked itself out. Strangely enough while I was having issues, I was watching fuel pressure at idle. It would be pretty consistent @ 400psi, but then would spike to 3600+PSI but with 0 change in engine/idling behavior. Perhaps my direct injection sensor is going bad but if it ain't broke right now don't fix it right? |
#11 | |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#12 | |
Thank you for that link, what a wealth of knowledge! |
| The Following User Says Thank You to norcalpb For This Useful Post: | Ultramaroon (08-03-2022) |
#13 |
Remember, not my stuff. I only link to it in my sig line. Good luck! Keep us posted.
#14 |
An IT tune up!
| The Following User Says Thank You to Tcoat For This Useful Post: | norcalpb (08-03-2022) |
| Solution Found: Rear Deck Rattle | jdubz | Issues | Warranty | Recalls / TSB | 29 | 10-13-2019 03:48 PM |
| Solution Found: Rear Deck Rattle | jdubz | DIY (Do-It-Yourself) Guides | 31 | 08-23-2015 06:08 PM |
| Has anyone found a solution to Kartboy shifter rattles and noises? | oliverc | Engine, Exhaust, Transmission | 1 | 06-16-2015 07:25 PM |
| Randomly getting CEL w/ code P0193 | YMAA | Issues | Warranty | Recalls / TSB | 18 | 07-31-2014 05:18 PM |
