| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 22 gr86
gen2 parts for oil change?
Anybody know the part numbers for the oil filter, crush washer, drain plug for GR86? Also, anybody have torque numbers for the filter assembly and drain plug?
#2 | |
Drives: 2018 Subaru BRZ
Filter and gaskets are the same as 13+ models. Both BRZ/86. You can find oil change kits at FTSpeed and 86Speed. Im not completely sure on torque specs though I can only assume is about the same as first gens. Get a fumoto valve, if you can, if compatible.
#3 |
Drives: 22 BRZ limited
The '22 filters are different. It has gone to the WRX filter now. I think it is the 170 vs the 130.
| The Following User Says Thank You to dragoontwo For This Useful Post: | spcmafia (07-15-2022) |
#4 | |
Good to know, FTSpeed has their oil package with the 13-20 filter included.
| The Following User Says Thank You to spcmafia For This Useful Post: | dragoontwo (07-15-2022) |
#6 | ||
Correction to my previous response. Oil Filter Part Number: 15208AA170 Crush Washer:803916010 (There's different ones listed) Torque: 28.9 Ft/Lbs (Or whenever is nice and snug if you don't have a torque wrench) Don't need to replace the plug every time, just try not to damage it. (17007AA010) Fumoto Valves: F-108, F-108N, F-108S, F-108SX
| Question regarding what parts from Gen1 will fit Gen2 | 370zBRZ | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 4 | 03-21-2022 01:52 PM |
| 2019 Engine into 2013 Chassis - Parts Change List | Car Bloke | Engine, Exhaust, Transmission | 8 | 10-26-2020 12:11 PM |
| Timing Cover Leak - What other parts should I change while I'm in there? | FR & S | Engine, Exhaust, Transmission | 7 | 12-09-2019 03:39 AM |
| First oil change parts question | stlgrym3 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 10-26-2018 03:59 PM |
| e85 tune. change rubber parts? | asphalt_fr-s | Software Tuning | 5 | 03-25-2014 12:28 PM |
