04-08-2022, 03:16 AM | #813 |
Because compromise ®
Drives: Red Herring
The Following User Says Thank You to Captain Snooze For This Useful Post: | soundman98 (04-08-2022) |
04-09-2022, 12:02 PM | #814 | |
Drives: 1993 Caterham HPC Evo
https://canadiangunnutz.com/ Everything you need to know about weapons in Canada can be found in the forums with some digging. Lots of stuff for sale. The main guys are good to filter out the true nut cases and you'll find some very knowledgeable people willing to help you make the best choice. Good luck. |
The Following 2 Users Say Thank You to Stephen W. For This Useful Post: | soundman98 (04-09-2022), wolffbite (04-09-2022) |
07-12-2022, 10:42 PM | #815 |
Just the tip
Drives: 2017 DGM BRZ
So as of today... my application has gone through initial processing!
Based on what I've been reading on Canadiangunnutz I won't hear anything further until fall at the earliest. |
07-13-2022, 08:05 AM | #816 |
Be Kind
Drives: 2020 86
Form 4s (for two YHM R9s) have been certified through Silencershop's "Full Auto" system! WHoo hoo!
07-14-2022, 06:12 PM | #817 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
On kinda of a lever journey now... recently got a used Marlin 30AS from early '90s in 30-30 Win and modded/rebuilt to a more modern multi-role gun:
Can run it just open sights (Skinner winged/ghost ring rear with .6" high x 3/8" wide front), with an M21 holographic and Holosun laser (as shown), with a long eye relief 2-7×32 pistol scope, or with a night vision scope. Have only put 60 rounds through it so far, but have it currently zeroed for 50yards and it is the most fun have had shooting. What currently have incoming is a decade old Miroku/Winchester 1885 high wall BPCR Limited Series Target single shot lever rifle in 45-70. Will be reloading with good higher BC 405grn to 600grn bullets for it since factory ammo for 45-70 is quite expensive ($3-$4 per round) and usually only FN bullets in 300-405 grain range. Only change am doing is adding an MVA Soule rear sight and globe front sight to it... will look similar to this one: http://www.bpcr1885.net/long-range-bpcr/
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
07-15-2022, 09:10 AM | #818 |
helmholtz resonator
Drives: '15 ultramarine
Never seen optics on a brush gun. Interesting.
The Following User Says Thank You to Sapphireho For This Useful Post: | Dadhawk (07-15-2022) |
07-15-2022, 03:39 PM | #819 |
Here it is both naked and with the Burris pistol scope in scout configuration (need to get it zeroed @ 100yards):
Really like it with the Mepro M21 and Holosun laser since it's quick acquiring and absolutely nailed steel gong as quick as could run the lever. Should work fine to about 100 yards and with Burris scope should be good to about 200 yards. For anything past that my inclination would be using my new lightweight precision bolt rifle, the Sig Cross in .308:
07-21-2022, 02:38 AM | #820 |
Something I got in the other day, modern version of a classic:
humfrz probably remembers when the original version was introduced... It's the Winchester 1885, specifically a High Wall .45-70 Govt. BPCR Limited Series Target version built by Miroku for Winchester about a decade ago. Have custom Soule style rear and aperture w/level front sights currently being made for it by Montanna Vintage Arms (MVA) which should be done within a month. Will have nearly 290MOA elevation and 90MOA windage adjustment available if I should ever want to push it long range... will be working up hand loads for 405gr FN and 535grain Postell cast bullets once I harvest the cases from some factory PRVI .45-70 I have coming in. Might just have to get a scope for it in the mean time...
07-21-2022, 11:27 AM | #821 |
Drives: Crapcan
One of my buddies just picked up a Cross. They are very nice, surprisingly light for as stout as it looks. Pretty sure it is lighter than my Ruger precision rimfire. He just has an ACOG on it now till he gets a new optic for it.
07-21-2022, 06:59 PM | #822 | |
The fixed 1" Leupold Backcountry aluminum rings that were originally on the Sig Cross can be used with 1" to 3/4" delrin spacer inserts on a vintage WW2 style M1903A4 rifle sniper scope (Hi-Lux M73G4) for mounting on the 1885 Winchester before the Soule sights come in. Should be a decent and robust enough optic and a look pretty good paired with the 1885 I think - not an out of place aesthetic like a fully modern scope would give. Also just got in the 45-70 Govt. 535gr postell bullets... here's a size comparison of one with a .308 Win 168gr Hornady Match BTHP bullet...
08-01-2022, 12:34 AM | #823 |
Just the tip
Hooray!
The Following 2 Users Say Thank You to wolffbite For This Useful Post: | soundman98 (08-01-2022), Stephen W. (08-01-2022) |
08-01-2022, 07:05 AM | #824 |
Be Kind
Drives: 2020 86
08-01-2022, 07:38 AM | #825 |
1st86 Driver!
Every time I see the "business end" of a bullet, etc all I can think is after so many millennium most of our best weapons are still just better ways to throw a "rock".
Where's my phaser?
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | Capt Spaulding (08-03-2022), DrinkenBRZ (08-16-2022), soundman98 (08-01-2022), Spuds (08-01-2022), Wally86 (08-01-2022) |
08-15-2022, 02:46 PM | #826 |
Just the tip
The Following 2 Users Say Thank You to wolffbite For This Useful Post: | NoHaveMSG (08-15-2022), soundman98 (08-15-2022) |
Similar Threads | ||||
No Politics or Religion discussions please | Hachiroku | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-07-2021 12:50 PM |
Product Showcase - Auto Finesse Tripple - All In One | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 11-16-2012 04:28 PM |
Product Showcase: Menzerna Fast Gloss 400 | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 11-16-2012 09:14 AM |
FR-S vs. 370z, end all be all of discussions | OldSkoolToys | FR-S / BRZ vs.... | 1491 | 09-25-2012 06:58 PM |
Are politics off limits? | Longhorn248 | Site Announcements / Questions / Issues | 35 | 05-16-2012 10:24 PM |
