Old 07-13-2022, 11:57 AM   #1
Robbie7c
Drives: 2013 Subaru BRZ
Shuttering While Cornering Hard
I've got a 2013 Subaru BRZ, I've had it for about 3 and a half years, and it has 220000kms on it. It's my daily that I drive about 200km a day in so I rack up the kms pretty quick!
Anyway, I've had an issue that's just recently surfaced. When I corner hard it seems to shutter/shake, only on the limit and it's when I start to get on the gas. This leads me to believe its maybe wheel hop?
Incase there's any other issue it could be that's not wheel hop I thought I should ask.
If it is wheel hop, what seems to be the most common cause of this?
The car is 100% stock.
Robbie7c is offline   Reply With Quote
Old 07-13-2022, 12:02 PM   #2
How are your tires? I found when my FRS tires were at the end of their life they would give the traction control fits when cornering.
jcw99 (07-14-2022), Ultramaroon (07-13-2022)
Old 07-13-2022, 12:38 PM   #3
Robbie7c
They’re definitely getting worn out, hoping to get the rest of this summer out of them. If that’s the issue that would be easy!
Old 07-13-2022, 12:52 PM   #4
That would be my bet then.
e_lunatic (07-13-2022)
Old 07-13-2022, 01:51 PM   #5
Quick test to confirm would be to long-press the traction control to defeat it. Don't worry. It's not like the car suddenly becomes a Mustang.
soundman98 (07-13-2022), Tcoat (07-13-2022)
Old 07-13-2022, 02:04 PM   #6
Robbie7c
Yeah that’s a good idea! I’ll try that.
And yes I’ve used that button a time or two, its a fun button, especially in the winter!
The Following User Says Thank You to Robbie7c For This Useful Post:
Old 07-13-2022, 10:17 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Rotate your tires. See if the behavior changes.
Old 07-13-2022, 11:17 PM   #8
e_lunatic
Drives: 2015 Scion FR-S
I agree with Tcoat thats what it sounds like to me as well.
e_lunatic is offline   Reply With Quote
Old 07-14-2022, 09:05 AM   #9
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Worn struts can also do this...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Tcoat (07-14-2022)
Old 07-14-2022, 11:08 AM   #10
And bushings, bearing, etc, etc.
Start at the parts that touch the ground and work your way up.
Opie (07-18-2022)
Old 07-14-2022, 11:12 AM   #11
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Perhaps stating the obvious, but this sounds like understeer to me. Coupled with the "only on the limit", have you considered that this might be driver input (e.g. a result of your braking, weight transfer, speed and steering wheel angle being incorrect for the corner?) I ran into this when I first started HPDEs... even though I was slower than I am now.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 07-14-2022, 01:34 PM   #12
e_lunatic
is the traction control kicking in while this is happening?
Old 07-14-2022, 04:02 PM   #13
I suspect that is the "shuttering*" he speaks of.
*Shuddering
Shuttering while turning would indeed be a pain!
blsfrs (07-15-2022), ZDan (07-14-2022)
Old 07-15-2022, 10:59 AM   #14
blsfrs
blsfrs's Avatar
Not to be confused with stuttering.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
alphasaur (07-15-2022), Tcoat (07-15-2022)
Clunking on hard cornering from front suspension Open Loop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-01-2017 09:47 AM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 02:04 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 01:49 PM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 09:06 AM
