| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 scion fr-s
Brz Blowing Smoke
Hey guys, so a buddy of mine has a 2019 brz with approximately 20k miles on it it has a full cat-less exhaust and is tuned using oft stage 2 (93 octane). He’s the first owner bought it off the lot. and right at about 17k i had noticed his car was blowing a little bit of white smoke (sometimes blue tint to it) and we had blown it off just as condensation but now at around 20k it has gotten a lot worse, Clouds of white smoke on startups both cold and hot and blue smoke sometimes while driving. We had preformed a head gasket test and it seemed fine and he’s been checking up on all his fluids and it doesn’t even seem like it’s burning anything… i’ll include a link to a video of the startup here vvvv
https://youtube.com/shorts/aVd1lEe0q5w?feature=share I’m pretty lost as to what it is, you would assume head gasket issues but the oil and coolant aren’t mixing and no fluids are being lost but it’s pretty smokey?
#2 | |
Drives: 2018 Subaru BRZ
Blue Smoke = burning oil Thick White Smoke = burning coolant Some white smoke = vapor Black smoke = too much fuel
#3 | |
#4 | |
Check the replies on the posted thread link. Steve99 has some good answers when it comes to tuning and problems related to it.
#5 |
Drives: Crapcan
Quick and easy thing to do is log the car with OFT and upload it to datazap.me and post the link here. Follow the logging steps in the link in the signature line of user steve99 in the link spcmafia posted. No guarantees' but we may see something there. Log the following:
Engine Speed (rpm) Throttle (percent) MAF Voltage (volts) Engine Load (g/rev) Ignition Advance / Total Timing (degrees) AFR Commanded AFR LTFT (percent) Oil Temp (F) CL/OL / Fuel Sys Status (2 = CL, 4 = OL) IAM / Ignition Advance Multiplier Knock Correction (degrees)
#6 |
#7 |
Drives: 2013 frs base
Maybe pull the pvc hose off the intake. See if there is excessive oil in the hose. Same for the valve cover vents.
| Tags |
| headgasket |
| AC Blowing Hot Air on everything but LO | pooyab | Issues | Warranty | Recalls / TSB | 13 | 12-31-2024 09:06 PM |
| AC not blowing any cold air | highway7 | Issues | Warranty | Recalls / TSB | 33 | 12-10-2021 10:58 PM |
| Air blowing out of vents with AC/fan off??? | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 16 | 07-11-2017 10:57 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 04:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 10:14 PM |
