Old 07-06-2022, 10:34 AM   #15
Shadow6
Drives: 2014 Scion FR-S
Yeah, I lack both an oscilloscope and any understanding whatsoever of how to use one.
I think I’m looking at swapping DI injectors around this weekend to see if that moves my misfires. Do I need to order any new gaskets or anything? I assume new intake manifold gaskets? New fuel injector o-rings?
If it is the injector should I just replace the bad one? Anyone have a suggestion for where to get a new one?
2014 Scion FR-S M/T
DD, autocrosser, track day car
Shadow6 is offline   Reply With Quote
Old 07-06-2022, 01:14 PM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
The DI's have teflon seals that require a special tool to install and then they are a bit of a PITA to get back into the engine. (IMHO)Your best bet is to find an injector shop that can clean and service DI's and PI's.
Is the bottom bolt on you DI ecu tight?
Old 07-06-2022, 01:44 PM   #17
Shadow6
P219A P119F poor idle quality
Hmm, I think I might check that bolt (is there a photo you can link me to?) and throw spark plugs at it/swap coils. If that doesn’t change anything I guess I’ll have a mechanic pull the DI injectors and send them out for cleaning. There’s a guy here in Ohio that does it.
I was afraid DI injectors would be a pain just because of the pressure involved both from the fuel and the combustion. Damn.
Edit: no sense playing with swapping around injectors if I’m paying someone to do it right? I just ought to send them out?
2014 Scion FR-S M/T
Old 07-06-2022, 10:28 PM   #18
blsfrs
blsfrs's Avatar
The DI ecu is the box on the pass side of the engine. It has 4 plugs going in to it's rear. There is a bolt on the bottom in the center that is the ground. You have to feel for it with your fingers (be gentle). Long shot, but make sure it's tight.
Send the PI's for cleaning too. Yes, I'd definitely send them out for cleaning. Whether you pay someone to take them out or diy is up to you. I did a lot of reading and video watching before I installed mine. It was nerve racking and luckily it turned out ok.
Old 07-06-2022, 10:56 PM   #19
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
DI seals are a pain but kids with aprilias can do them with a tapered punch, a piece of hose and a hose clamp, that's how I do them on VWs. Lightly expand the teflon seal on the puch until it can barely get on the tip, slide it into the groove, slide piece of hose on the seal and tighten hose clamp to shrink it back on. let it rest clamped while you replace the seal on the next injector.
DI seals aren't *that* fragile, they'll survive one R&R. Clean the tips with intake cleaner, give it a drop of oil and sliiiide it back in. See if issue follows, if it does, order one injector and one seal kit, if it doesn't two seal kits to close it back up for good.
Old 07-07-2022, 10:09 AM   #20
blsfrs
blsfrs's Avatar
Your experience with DI's is different that mine (and others on this forum). My injectors would not just slide in. I had to freeze and lube them then push them in by tightening them down with the fuel rail bolts.
I watched videos of other car's DI and indeed, they appeared to slide in with finger pressure but ours won't.
I like your technique of "shrinking" the seal. I'll try that, if I ever have to deal with those b***ches again.
Old 07-07-2022, 11:45 AM   #21
Shadow6
Sounds like I have some videos to watch.
2014 Scion FR-S M/T
Old 07-07-2022, 01:26 PM   #22
blsfrs
blsfrs's Avatar
Read through this. There a a few other threads too.
https://www.ft86club.com/forums/show...irect+injector
The Following User Says Thank You to blsfrs For This Useful Post:
Shadow6 (07-07-2022)
Old 07-07-2022, 01:59 PM   #23
RZNT4R
yeah, i haven't had the pleasure of dealing with an fa20 DI, but of everything i've touched, the only ones that don't pull out with the fuel rail are the diesels, and BMWs. Just did a Nissan juke, half came with the rail, half came out of the head with a light tug :lol
The Following User Says Thank You to RZNT4R For This Useful Post:
blsfrs (07-07-2022)
Old 04-01-2023, 09:38 PM   #24
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
Did replacing or cleaning the di and port injectors work?
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
P0301, P219A, P119F, P119E BrZ_Good Issues | Warranty | Recalls / TSB 10 04-16-2025 11:33 AM
P119F P219A + out of warranty ? zippee Issues | Warranty | Recalls / TSB 12 03-19-2021 01:32 AM
P219A, P119F - Air Fuel Ratio Imbalance hui202 Issues | Warranty | Recalls / TSB 14 08-16-2019 07:47 PM
P0302, p219a, p0352, p119f, used car woes. Dara321aaa Issues | Warranty | Recalls / TSB 8 04-29-2019 10:44 PM
Click/clanking sound w/ P219A, P119F, P0302 Kentoxik Issues | Warranty | Recalls / TSB 7 01-24-2019 10:23 PM
