Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-06-2022, 05:30 PM   #1
Andrew Barden
Andrew Barden's Avatar
Drives: 2022 GR86 Manual Base
Disable voice control button?
I’ve had my GR86 under a month and had it out autocrossing 3 times. Every time I catch an oversteer, my hand hits the speech button on the steering wheel (bottom right) which prompts the robo voice to ask a bunch of questions. Needless to say, that is the exact time I don’t want to hear anything unexpected or be asked questions. Anyone know how to deactivate this useless button/feature?
Andrew Barden is offline   Reply With Quote
The Following 3 Users Say Thank You to Andrew Barden For This Useful Post:
bcj (07-06-2022), Frost (07-06-2022), Krokodil (07-06-2022)
Old 07-06-2022, 11:06 PM   #2
BlkTrax
Drives: Car
So possibilities...
You can try pulling fuse #9 in the interior fuse panel. This is the ignition power to the Cockpit Control Module (radio) and active sound generator. Not sure what codes might set. Easy enough to pull it and take a test drive. If it doesn't set a check engine light then it shouldn't be in limp mode. But then likely no control over the cluster screen, and possibly no traction control switch function.
Option 2 would be to put a toggle switch on the red ground control wire in the steering column. All the steering wheel switches work off resistance and 2 signal wires and 1 ground. Open the ground with a switch while auto-x all the steering switches are inop, click the switch back all of them work. HOWEVER... because the switches work on resistance if the splice or the switch is less than quality, it may cause phantom button presses... when turned on.
Option 3 , aftermarket steering wheel , because racecar.
You can go into the sound menu and turn the voice assistant volume all the way down or press the talk button and as its speaking turn the volume knob down.... the screen changes and displays the prompts, but then nothing is heard, but it I found also turns down SIRI and you have to remember to turn it back up if you use that function.
BlkTrax is offline   Reply With Quote
The Following User Says Thank You to BlkTrax For This Useful Post:
jongers (07-07-2022)
Old 07-07-2022, 12:26 AM   #3
eyeballs
Drives: '22 BRZ
I have the same problem, though though it happens in more situations then just oversteer correction. Very annoying.
eyeballs is offline   Reply With Quote
Old 07-07-2022, 07:42 AM   #4
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
I find it a nice touch that swearing at the robo-voice when you accidentally hit the button makes it cancel. Someone was thinking when they coded that.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to 22 BRZ For This Useful Post:
Desertnate (07-07-2022), racingfool (07-07-2022), soundman98 (07-08-2022), timurrrr (07-08-2022)
Old 07-07-2022, 07:58 AM   #5
Andrew Barden
Originally Posted by BlkTrax View Post
So possibilities...
You’re a legend man, that’s a thorough response. I’m going to turn the volume down (and maybe try telling it to F off) to start, break out the soldering iron as a last resort. Thanks!
Old 07-07-2022, 11:25 PM   #6
otter
Drives: 22 BRZ
The source button seems to be the one I hit the most. I've gotten in the habit of muting, turning the screen off, and unpairing my phone on autox days to avoid random bullshit from the ICE.
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
Old 07-08-2022, 07:40 AM   #7
Andrew Barden
I do that too, but the voice still works with everything off grrrrrr
Climate control button part number? BR-ZED Electronics | Audio | NAV | Infotainment 3 03-22-2022 10:13 PM
disable the trunk release cancel button Riftur Electronics | Audio | NAV | Infotainment 19 02-13-2016 01:35 PM
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 05:58 AM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
BRZ Voice Control touge-n00b Electronics | Audio | NAV | Infotainment 3 04-03-2013 04:11 PM
