Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-03-2022, 02:49 AM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Do 215's look stretched on the stock gen2 7.5" wheels?
For 2022 owners out there, does the stock 215 tires look stretched on factory wheels which I believe are 7.5 inches? If you could also say what tires you have
I'm ordering 215 PS4S's for my new new Enkei GTC02 wheels which are 7.5 inches and really hope they don't have a stretched look.
My current 215 Primacies look ever so slightly stretched on my factory 2017 wheels which are only 7 inches, but I'm thinking PS4S tires are visually wider than the primacies even on the same size
ItsReiko is offline   Reply With Quote
Old 07-03-2022, 03:39 AM   #2
DarkSunrise
DarkSunrise's Avatar
Yes they look slightly stretched. I don’t think it looks bad but you can decide for yourself. This is the oem 215 primacy on the 7.5” base wheel.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
ItsReiko (07-03-2022)
Old 07-03-2022, 10:49 AM   #3
AK2112
AK2112's Avatar
Drives: 22 BRZ
Yup, the 215 Primacys are stretched. I don't love it.
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
Old 07-03-2022, 12:50 PM   #4
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
+1
I'm going to start running all-seasons on my stock wheels and I'll be going with 225s instead of 215s.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 07-03-2022, 03:53 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Some tires for wider which helps. PS4S fit a bit wider than the primacy from my understanding which should help fill the wheel better. Michelin's site isn't listing the actual tread width.
The primacys on 7.5" wheels looks similar to 215 PS4S on my 17x8s.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 07-03-2022, 05:32 PM   #6
pitter
Drives: bRed GR86
I put 225s on the OEM 18s and it's more square. looks way better IMO
pitter is offline   Reply With Quote
The Following User Says Thank You to pitter For This Useful Post:
DylanJZA (07-12-2022)
Old 07-04-2022, 07:21 PM   #7
Krokodil
Drives: Blue BRZ
215 on 7.5 looks a bit stretched, but feels perfect
Krokodil is offline   Reply With Quote
Old 07-04-2022, 07:30 PM   #8
OkieSnuffBox
Drives: '23 BRZ Limited
Stock, I'm sure. But if you were getting into the 200TW and RComp stuff, not necessarily.
For RComps in the Miata world, we ran 205s on 8, 225s on 9, 245s on 10s and 275s on 11s.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 07-04-2022, 08:41 PM   #9
Krokodil
Drives: Blue BRZ
Are you guys running so stretched tires to give more support to tire with soft sidewall and low inflation pressure?
And this is probably on track, not autox, right?
Old 07-04-2022, 09:52 PM   #10
foshjowler
Drives: 2022 BRZ; 2014 BRZ
The rim protector certainly makes it appear more stretched than it actually is.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 07-05-2022, 11:55 AM   #11
OkieSnuffBox
That's why I specifically brought up 200TW and Rcomps, they run WIDE. My 205s were barely stretched on an 8"
Still ran normal pressures, but yes, a tiny bit of stretch does help sidewall stiffness and the tires more responsive to inputs without losing grip.
Old 07-05-2022, 02:47 PM   #12
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
EDIT: I washed my car last night and took a good look at the tires while cleaning the wheels. Ignore everything I said below. They are bit stretched, even without the visual distraction of the tire's rim protector.
I was thinking the same thing.
The OEM 215 PS4's on my car seem to be pretty flush with the side of the wheel, but the rim protector creates a slight slope to the sidewall which makes it look slightly stretched.
Desertnate is offline   Reply With Quote
Old 07-05-2022, 04:08 PM   #13
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
As said above each tire manufacturers 215 tire will be slightly different sizes on the wheel.
Even within one manufacturer the same size and aspect tire may be different width or height depending what model tire you're running.
Old 07-08-2022, 01:12 AM   #14
eyeballs
Drives: '22 BRZ
A little stretch is not a bad thing, and is usually advantageous from a performance standpoint. I ran 215s on the stock 8" wheels on my rx8 (found a set of firehawk indy 500s super cheap in that size) and they worked surprisingly well on street and track. For 200tw track tires on my miatas I ran 205's on 8" width and 225 on 9" width.
eyeballs is offline   Reply With Quote
WTB: OEM Gen2 18” wheels and tires Brady83 Want-To-Buy Requests 2 02-15-2022 11:42 AM
stretched stock frs tires on aftermarket wheels JarredH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 01-27-2016 08:18 PM
Anyone have pic of Series.Blue with Prokit on stock "sti" wheels??? UrmyboyBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-23-2015 05:56 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 09:17 AM
