Old 08-01-2012, 06:42 PM   #1667
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by FTEIGHTSIX View Post
I swear we had a MAF instead of a MAP.
Isn't Don running a blowthru MAF setup on his car?
There is both, The MAP is used to control idle, and the MAF is used for fuel calculations.
G
darn, Don beat me to it HaHa, but mine was a little more thorough
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 08-01-2012, 07:34 PM   #1668
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
Originally Posted by Don@Accelerated View Post
I'll post pictures of it later. I'm testing some new stuff right now!
Thanks Don. Whenever you have time.
Although, I am a bit curious..
What new stuff?
There is both MAF and MAP
G
I am enlightened.
FTEIGHTSIX is offline   Reply With Quote
Old 08-01-2012, 07:52 PM   #1669
Synack
Boosted
Synack's Avatar
Drives: Sideways
You are limited by the stock MAP sensor, and it is only reads slightly above atomospheric.
G
Is there a replacement that reads higher levels?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-02-2012, 01:19 AM   #1670
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Going off the parts-bin method, I would assume there are subaru replacement sensors that read 2 bar or even 3 bar.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Synack (08-02-2012)
Old 08-02-2012, 10:26 AM   #1671
Don@Accelerated
Don@Accelerated's Avatar
Little Picture of machining the compressor covers. Preparing a few kits for shipment.
Don@Accelerated is offline   Reply With Quote
The Following User Says Thank You to Don@Accelerated For This Useful Post:
tripjammer (08-14-2012)
Old 08-02-2012, 10:27 AM   #1672
Don@Accelerated
600HP intercooler setup and fitment. Testing fitment and cooling effect on my car! Obviously were not to needing a core this large yet, but i'm working out all the issues for when i'm ready here later this year.
Old 08-02-2012, 10:52 PM   #1673
Don@Accelerated
All locked in for Monday. John is coming to test and he'll be available as well to flash his stg1 packages. Anyone within driving distance should consider driving over. Oh and did I mention we'll be dyno testing 2 turbo cars. One FRS and one BRZ.
The Following 3 Users Say Thank You to Don@Accelerated For This Useful Post:
civicdrivr (08-04-2012), cobrabyte (08-02-2012), tripjammer (08-14-2012)
Old 08-02-2012, 10:57 PM   #1674
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
I would be there if I had my car.
WiKKiD is offline   Reply With Quote
Old 08-02-2012, 11:03 PM   #1675
Don@Accelerated
There are alot of people on here without cars. Sleeping at the wheel....Drive to buy one if you want one so bad. I drove hundreds of miles for mine.
Old 08-02-2012, 11:27 PM   #1676
rusty959
Drives: DGM BRZ limited
Ive always wondered, is there a point to having that big of a core if part of it is blocked off from airflow anyways? Doesn't seem like it would be doing all that much.
rusty959 is offline   Reply With Quote
Old 08-02-2012, 11:33 PM   #1677
Don@Accelerated
Yes and no. Although it would be nice to have airflow over the entire piece, it is still a heat sink and cooling half of it still cools the whole thing. Luckily aluminum has great thermal transfer across itself.
Secondly you can only push so much air through the smaller core. This core is more for moving cfm than cooling. Overkill for where the car is in its current state.
Don
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
rusty959 (08-03-2012), tripjammer (08-14-2012)
Old 08-03-2012, 02:08 AM   #1678
jedibow
yes,
but they would require scaling to work with the EGR system correctly.
G
Old 08-03-2012, 10:51 AM   #1679
2jzge
Drives: Jeep
The four main variables to optimizing a heat exchanger system like and air to air intercooler are frontal area, mass flow rate of ambient air, distribution of ambient air across frontal volume, and fin design.
Just because the frontal area isn't directly open does not mean you can't duct air to be distributed across the face.
2jzge is offline   Reply With Quote
Old 08-03-2012, 11:48 AM   #1680
Synack
Boosted
Synack's Avatar
Drives: Sideways
Looks like I'll be sticking to a good ole standard boost gauge. Speaking of which, are there any pillars available yet?
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
