Old 01-27-2022, 05:58 PM   #155
Colin86
Drives: 86
I've been interested in performing this mod but struggling to find these modules, and Lee's parts never seems to have them in stock. Any other advice?
Thanks in advance!
Colin86 is offline   Reply With Quote
Old 01-27-2022, 06:14 PM   #156
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Thanks in advance!
Keep an eye on 417motoring on eBay:
https://ebay.com/usr/417motoring
Old 03-22-2022, 07:05 PM   #157
RedReplicant
Drives: None
Does anyone know if the ABS is less intrusive on the newer units too?
RedReplicant is offline   Reply With Quote
Old 03-23-2022, 04:45 AM   #158
churchx
churchx's Avatar
Drives: 2014 GT86
If you trigger ABS / locking wheels on braking, most probably you do something wrong with driving inputs, brake too late, turn too much while not having yet eased brakes enough in trailbraking or overdid on braking while treshold braking.
Or you meant VSC intrusiveness, not ABS, which this thread is mostly about? (track mode/pedal dance and alikes leave ABS on).
Old 03-29-2022, 12:21 AM   #159
RedReplicant
Drives: None
I'm more asking about ice mode
Old 04-06-2022, 06:42 PM   #160
RedReplicant
Drives: None
In interest of more data, my friend stopped by with his new 2022 GR.
27536CC001
Pump motor has a different cover, output brake lines are a different color.
Old 04-22-2022, 11:21 AM   #161
Colin86
Drives: 86
Just wrapped up this DIY, thank you so much for everyone who contributed/documented this! Few tips for those fielding this:
The big wiring connector that plugs into the stability control module will not plug back in unless the pink sliders (used to lock the wires) are in the "locked" position. Don't force it, it should slide on easily.
Similarly, when pulling the wires out to re-pin them... If the wires are unlocked they should pull out of the connector with ease, you shouldn't have to force them at all. If you have to pull the wire with much force it's likely locked, check the pink connectors again as well as the locks in the front side.
Lastly, I went for a drive after completing this and attempted a hill start to "confirm" the new programming was there. When hill start didn't work I was concerned I did something wrong, but searching on these forums confirmed hill start is not enabled by default. I don't want/need it so not an issue here, but if you're using the hill start test as a way to confirm you're set you'll have to enable it.
Old 04-23-2022, 08:54 AM   #162
makinen
makinen's Avatar
Drives: Toyota 86
By just pressing VSC Sport button (now Track mode). It'll take 1 second to turn on.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
Yoshoobaroo (04-23-2022)
Old 05-23-2022, 06:43 PM   #163
cueball89
Drives: 15 Impreza
Selling a 17+ MT module I ran on my 16 BRZ if anyone is interested.
https://www.ft86club.com/forums/showthread.php?t=149855
cueball89 is offline   Reply With Quote
Old 06-28-2022, 10:27 PM   #164
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Sad lights...
gcranston is offline   Reply With Quote
Old 06-29-2022, 02:53 PM   #165
norcalpb
norcalpb's Avatar
Originally Posted by gcranston View Post
Sad lights...
Dang, is this after the install?
Old 06-29-2022, 10:10 PM   #166
gcranston
Yep. Code is U0122 lost communication with vehicle dynamics control module. Yes I did the repin. 2013 FRS. I'll pull out alert tomorrow and check I have things in the right place. Anyone else get this code?
Old 06-30-2022, 01:31 PM   #167
RedReplicant
Drives: None
Did you ever get the original unit working before you tried the 2017?
Old 06-30-2022, 01:46 PM   #168
gcranston
Nope. For background, I posted here about issues I was having with pedal dance, and 4 ABS module codes I had: https://www.ft86club.com/forums/showthread.php?t=146096
C1237: Speed Wheel Rear Input Signal Missing
C1332: Open Circuit In Right Rear Speed Sensor Circuit
C1333: Open Circuit In Left Rear Speed Sensor Circuit
C1464: Front Speed Sensor Right
C1465: Front Speed Sensor Left
C1541: Vehicle Speed Signal Malfunction
Instead of trying to fix that issue with the original controller -- and I don't know how would do that without replacing in kind -- I decided to try this upgrade to the 2017 controller. That way I might not need my tracbox or at least I'd have options. I tried the swap described in this thread and the photo and U0122 code a couple posts above was the result.
I've got an even this weekend, so at this point I'm going to check I got the wires in the right pin locations with the 2017 module. If that's not the issue I'm putting the old module back in. 5-sec hold will have to do for now. Appreciate any suggestions you all might have.
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 10:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-21-2020 12:27 AM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 11:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 11:34 PM
