Old 03-02-2022, 02:41 PM   #1
mgrabo1024
Drives: 2013 FR-S, Hot Lava
2020 BRZ head unit into the FR-S (2013)
I recently acquired a cheap head unit from a 2020 (P/N 86271CA690) part out. it was listed as unknown functionality. so I took the gamble hoping to get android auto in my 2013, it was cheap BTW.
After plugging in the head unit, to my surprise it powered up after plugging it in and cycling the key. but I had a few issues that maybe more knowledgeable people can help with.
1st when I turned the key off the radio stays on.
2nd USB connection for android auto doesn't work, also usb drive with music won't work.
3rd the built in map/gps system shows me being in California, i reside in NY.
(I think i figured out I don't have the add in GPS antenna for this)
4th I have an aftermarket back up camera which doesn't work.
(I was left with 1 extra connector which i believe contains the camera connection.)
mgrabo1024 is offline   Reply With Quote
Old 03-10-2022, 09:10 PM   #2
mgrabo1024
I did figure out the turning off isn't an issue. It will go off on its own after a few minutes(2-5 minutes approx.) I ordered a 28 pin adapter which should allow me to plug in my back up camera. I also have a GPS antenna on the way to see if I can get nav working. I just got in a usb port plus wires to check android auto connection.
Old 03-20-2022, 06:49 PM   #3
mgrabo1024
Gps antenna is in I now have working built in navigation. Usb cables were i have dual ports plus iadded plus power to the aux unit under the radio. And I now have working android auto. I still need to get my backup camera working.
But definitely made progress after reviewing wiring schematics for a 2018 BRZ and looking for missing connections vs my 2013 FRS
Old 05-28-2022, 01:46 PM   #4
coolhandluke
coolhandluke's Avatar
Thank you for sharing your advice and experience. I may hunt a 2020 HU for my 2013.
coolhandluke is offline   Reply With Quote
Old 06-02-2022, 03:48 PM   #5
mgrabo1024
I have recently supplied my documents (excel sheet) to someone on a face book group. He recently completed the same swap (2015 BRZ) and has almost everything up and running. If you need it I would be happy to share it.
Old 06-25-2022, 08:48 AM   #6
Ads
Drives: 86
Hi mgrabo, would I be able to grab that excel spreadsheet off you? I am about to put a 2020 86 head unit into a 2013 86.
I am hoping the only issue I have is the amp bypass, but it will be handy to have your notes if I run into any other issues. TIA!
Ads is offline   Reply With Quote
Old 07-05-2022, 12:34 AM   #7
coolhandluke
Thumbs up
Myself and I see others would benefit from sharing the information here.
The Following User Says Thank You to coolhandluke For This Useful Post:
Grimm0ne (05-10-2024)
Old 11-24-2023, 11:46 PM   #8
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
Can you share your excel sheet? I’m in the process of taking on this project myself. Thanks!
2013 BRZ Limited WRB
ICEBONEZ is offline   Reply With Quote
Old 04-20-2024, 07:24 PM   #9
Grimm0ne
Grimm0ne's Avatar
Drives: 2013 Subaru BRZ
info would be greatly appreciated, moving a 2019 into my 13, need the pinouts to do the wire dance.
Grimm0ne is offline   Reply With Quote
Old 04-22-2024, 11:57 AM   #10
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Genuinely curious, with the large number of reasonably priced double DIN aftermarket HU's available these days, what's the advantage to upgrading to a later model OEM unit? Seems like even the latest infotainment units were considered by reviewers as less than desirable?
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
'?? 86 one day soon?
LRNAD90 is offline   Reply With Quote
Old 04-28-2024, 07:32 PM   #11
Grimm0ne
Grimm0ne's Avatar
for my 13, just want a factory look. I've looked at aftermarket ones and seems ok, back in the day when cars didn't have an upgrade option to swap to a newer model (my dsm days) I went Kenwood. Just like the look of factory. working on making a harness for the BRZ's but i just keep going in circles on the pinouts for the 2013's and the 2017+, it plugs in fine, but no backup and half the speakers don't work.
Old 04-29-2024, 09:38 AM   #12
LRNAD90
Try checking with Crutchfield, they probably have a document with the pinouts for each model year..
~Scott T.
'95 NAS D-90 ST
'13 BMW X5 35d
'22 CX-5 Turbo
The Following User Says Thank You to LRNAD90 For This Useful Post:
Grimm0ne (04-29-2024)
Old 04-29-2024, 12:40 PM   #13
Grimm0ne
Grimm0ne's Avatar
That hit me last night. Will shoot them an email and see, but thanks for that
Old 04-30-2024, 11:31 PM   #14
Dhanesh
Drives: 2013 Scion FRS
Hello. Can you share the GPS antenna and USB port that you installed in your car. I am planning to buy the same hear unit from eBay. 86271CA690. Did you have to instal the amp jumper harness as well?
Dhanesh is offline   Reply With Quote
Issue with 2020 Head Unit - Door Speakers dead etherdude Scion FR-S / Toyota 86 GT86 General Forum 80 10-24-2022 10:59 PM
2020 Hakone Head Unit and Amp blazephantom Audio/Visual, Electronics, Infotainment, NAV 1 06-19-2021 07:57 PM
Connecting Subwoofer to the head unit BRZ 2020 Teppka Electronics | Audio | NAV | Infotainment 1 06-17-2021 01:37 AM
WTB: 2020 Toyota 86 OEM Radio/Head Unit burgeralert Want-To-Buy Requests 7 08-16-2020 06:49 PM
