Old 06-21-2022, 03:33 AM   #1
captainsatch
Drives: toyota 86 MT 2.0
Engine parts to cover during engine wash. Missed the ECU.
Hi Guys,
Had an engine wash the other day in this local car wash and forgot to cover the ECU, well im not sure if it was the ECU of fuel injector module which is located near the fusebox, because I remember the ECU of the 86 is just under the dash passenger side ammi correct? does anyone have the same experience? Hopefully ECU was not damaged. So far my 86 is still running normal with no unusual sounds or abnormalities.
I had it pressure washed. Hopefully everything is just fine especially the ECU. Had alternator and other electrical components covered,
So what are the other parts that needs to be covered. Thanks a lot.
captainsatch is offline   Reply With Quote
Old 06-21-2022, 09:00 AM   #2
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
It'll be fine
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Ultramaroon (06-21-2022)
Old 06-21-2022, 10:39 AM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
If you had caused an issue, you'd already know about it. You would have known about it first start up after the wash.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Old 06-22-2022, 07:08 AM   #4
captainsatch
Thanks Guys! Yeah so far ao good i dont see, hear or feel any problems. Hopefully i wont have long term issues tho because of the engine wash I had. Thanks guys
The Following User Says Thank You to captainsatch For This Useful Post:
Wally86 (06-22-2022)
Old 06-22-2022, 07:11 AM   #5
Originally Posted by Wally86 View Post
If you had caused an issue, you'd already know about it. You would have known about it first attempt to start up after the wash.
FIFY
DarkPira7e (06-22-2022), Wally86 (06-22-2022)
Old 06-22-2022, 07:24 AM   #6
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
FIFY
Old 06-22-2022, 08:53 AM   #7
Grady
Grady's Avatar
You should be ok. Everything in the engine compartment should be IP65 or greater. I personally do not cover anything when cleaning my engine but do not use a pressure washer.
Old 06-22-2022, 10:27 AM   #8
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I wouldn't use a pressure washer either. You can get everything you need off with a regular hose and brush.
Qwimby1 is offline   Reply With Quote
How to wash your engine bay area (DIY) Packofcrows DIY (Do-It-Yourself) Guides 23 09-26-2020 10:39 AM
**SOLD**Blue engine Cover and Grimmspeed Pulley Cover Husker BRZ Engine, Exhaust, Bolt-Ons 2 03-24-2016 12:05 PM
WTB: OEM Engine Cover PhreshhWun Canada Classifieds 2 02-05-2015 02:35 PM
Engine Cover Sailors14FR-S Cosmetic Modification (Interior/Exterior/Lighting) 12 04-29-2014 01:44 PM
WTB Engine cover! Khazzy Engine, Exhaust, Bolt-Ons 10 08-23-2013 05:36 PM
