FRS 7443 CK or Standard?
This is probably a dumb question but searching for the term "CK" doesn't work because it's too short. I would like to get switchback LEDs for my front turn signals. There are a billion of them on Amazon but almost all of them are for the standard socket type rather than CK socket. Does anyone know if the FRS has a CK socket or Standard socket? I know how to test for myself but I don't feel like digging into the car to test and then ordering the correct LEDs just to dig back in there again to install. Something tells me they are standard sockets simply because for the life of me I can't find any discussion on this topic.
#2 |
I went ahead and checked for myself. The sockets are standard. The grounds are on the end. This means there are tons of LED options for this car.
| The Following User Says Thank You to ermax For This Useful Post: | Bonburner (08-12-2023) |
#3 | |
Drives: 2015 FR-S
https://www.diodedynamics.com/cf18-l...l-flasher.html |
#4 | |
Dang you are asking me to remember something form 2018? Hahahaha. It’s going to take some time to think about this one. If I recall I modified the OEM relay. For sure I did not buy the diodedynamics relay. Let me dig around a little and see if I can refresh my memory. |
#5 | |
Drives: 2015 FR-S
#6 |
ProCrastinationConsultant
Just get the led flasher. No reason to overcomplicate the setup with the resistors if a flasher is available
#7 | |
On the 2013 the DRLs have nothing to do with the flashers. I have LED high beams and to avoid the flickering DRL issue I simply disabled them using Techstream. |
| FS: 9005 LED&7443 LED Switch Back bulbs | Rican_D | Exterior Parts (Aero, Lighting, Etc.) | 6 | 01-16-2015 12:35 AM |
| 7443 led switchback -- do they hyperblink? | HotLavaChick | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-01-2015 03:13 PM |
| PSA: Flipped Connectors on Some VLED 7443 LED Bulbs | BagOfArms | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-19-2013 02:31 PM |
| Brightest 7440/7443 LED? V-LEDs worth it? | cdo221 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 06-24-2013 05:28 PM |
| 7443/7444 chrome bulbs | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-05-2012 11:16 AM |
