Old 05-24-2022, 01:38 PM   #1
amaurya
Drives: 2016 BRZ Limited
Exclamation Clicking noise that increases with speed from rear passenger side
Hi everyone, today I noticed an odd clicking or scraping noise coming from the rear passenger wheel of my 2016 brz limited. I jacked the car up and spun every wheel to see if I could recreate the noise but it didn’t work. Went for another drive and the noise didn’t reappear until breaking from about 60mph to 20mph then did not go away for the rest of the drive. I’ve attached two videos of the noise. Sorry if it’s a little hard to hear over the exhaust. Anyone know what could be causing the noise?
https://youtube.com/shorts/h_laDkYq8vQ?feature=share
https://youtube.com/shorts/ai9BeNrLPrU?feature=share
Regrading maintenance, I purchased the car from a dealer a little over a year ago at about 56,000ish miles and it now has 62,000 miles. The pads on all 4 wheels were replaced in January with ceramic pads and have plenty of brake material left. However the rotors have not been replaced ever I think but show no signs of unusual wear.
amaurya is offline   Reply With Quote
The Following User Says Thank You to amaurya For This Useful Post:
humfrz (05-24-2022)
Old 05-24-2022, 04:57 PM   #2
Hello amaurya, and welcome to ...... The Forum .....
I'd "guess" your car has a sticking caliper.
Old 05-24-2022, 05:29 PM   #3
norcalpb
norcalpb's Avatar
Take a look at your passenger axle and see if you can see any tears in the boots, excess grease and give it a shake front to back to see if it has play.
Old 05-24-2022, 06:25 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check axle nut torque. 143ftlbs.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Teseo (05-24-2022), thomasmryan (05-24-2022)
Old 05-24-2022, 10:35 PM   #5
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
from past experience, aftermarket pads can have a loose fit and make odd noises.
for starters, check to see if the temperature of that particular caliper is hotter than the others. If it is dragging, it will be hotter. It may just need a good cleaning.
Second, try bedding the pads again after cleaning and putting a dab of ceramic never-seize on the pad and hardware contact points.
I always go original equipment on brakes. It is best to avoid coming to a complete stop after hard usage until everything cools a bit...
thomasmryan is offline   Reply With Quote
Clicking / Popping noise from steering when not moving or low speed UNCC_BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-26-2022 11:31 PM
Thumping noise coming from rear passenger side? Ghosttothepost Issues | Warranty | Recalls / TSB 9 11-03-2021 06:15 PM
Clunk noise from rear passenger side. Any ideas? ImADuck Issues | Warranty | Recalls / TSB 36 08-08-2018 01:20 PM
clicking noise from drivers side rear CARBONGT86 CANADA 11 08-23-2015 07:58 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 06:55 PM
