Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-23-2022, 06:44 PM   #1
drift86
Drives: GT86, 22 BRZ
Door buzzing from speaker bass
Does everyone's door buzzes when certain bass frequencies are played through the speakers?
Anyone had any success getting rid of the buzz?
You can test it with this clip:
Mine buzzes like crazy between 50-75Hz...
drift86 is offline   Reply With Quote
Old 05-23-2022, 06:51 PM   #2
AK2112
AK2112's Avatar
Drives: 22 BRZ
Yeah, I've got a little bit of buzz.
I did have a lot when I first got the car but I figured out it was coming from the little plastic triangle pieces inside the interior door latch. I popped those off, put some friction tape on the back and then clipped them back in and now they no longer vibrate and rattle.
Now I just have a little bit of buzz from heavy bass but it's not nearly bad enough to where I want to go pulling the door cards off to chase it.
AK2112 is offline   Reply With Quote
Old 05-23-2022, 06:53 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
time for dynamat
HKz is offline   Reply With Quote
Old 05-23-2022, 10:07 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i stopped having problems once i rewired the car for full active, with a sub, and 80hz high pass on the doors.
Old 05-23-2022, 11:36 PM   #5
eyeballs
Drives: '22 BRZ
Mine was really bad. I had the dealer check it out while they had it for alignment. They said it was the wiring (or plugs?) for the window switch. It still rattles occasionally with extra low frequencies but it's infrequent enough not to bother me.
eyeballs is offline   Reply With Quote
Old 11-26-2022, 03:14 PM   #6
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Well go into settings and audio customization and I turned my treb to max my mid in the middle and the bass to 1/4 and give that a go. No more banging. This speakers aren’t made for booming bass at All.
vindiesel is offline   Reply With Quote
Old 11-27-2022, 12:14 AM   #7
eyeballs
Drives: '22 BRZ
At least in my case, it's definitely not a speaker issue. When the right bass tones play and it rattles, just putting mild pressure on the window switch panel completely eliminates the rattling. I have a new switch plate on order, hopefully it'll fit better then the original. If not, and it's the door card I'll let the dealer handle it under warranty.
Old 11-27-2022, 01:41 AM   #8
soundman98
soundman98's Avatar
A little felt goes a long way. Dealer don't do that
Old 11-27-2022, 09:38 AM   #9
WNDSRFR
Drives: FR-S,GTI
Funny story.
On my '13 a had a buzzing driver's door speaker. Took the door apart and foamed the speaker and all associated parts. Put it all back together and the buzz was still there.
Humm...
I notice that I have my garage door opener clipped to the bottle holder on the door. Removed it and the buzz was gone.
The Following User Says Thank You to WNDSRFR For This Useful Post:
soundman98 (11-27-2022)
Old 11-27-2022, 02:39 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
I don't know.. I never turn on the stupid 1970s system that Subaru think is suitable for this day and age..
The Following User Says Thank You to JD001 For This Useful Post:
bcj (11-28-2022)
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. The Sentinel DIY (Do-It-Yourself) Guides 3 01-28-2016 05:39 PM
Speaker Upgrades - That still have bass ka-t_240 Electronics | Audio | NAV | Infotainment 25 10-24-2015 10:35 AM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 10:45 PM
FS (NY): 2x10 bass speaker cabinet - tc electronics abutterman Miscellaneous 3 07-24-2013 01:16 PM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
