Old 05-17-2022, 04:30 PM   #127
ermax
ermax's Avatar
I am sort of embarrassed that I never noticed the change on the 2020 and could have told people there was an easy fix two years ago. Pretty sure that the face lift years had the changes done that the TSB covers. It really does work great although I do miss my car hugs every time I was parked on a 5 degree or greater slope.
Man you let us down.. hahaha.
I'm enjoying the door not slamming on me as I gather up my water bottle, running bag and other random stuff when getting to the office but it is strange not being able to close the door by simply looking at it. That was kind of a cool feature. hahaha
The Following 2 Users Say Thank You to ermax For This Useful Post:
Tcoat (05-17-2022), Ultramaroon (05-18-2022)
Old 05-18-2022, 01:35 PM   #128
FrickingReallySlow
Drives: 2015 FR-S
I also installed the 2022 brz door checker since it was only $24 from Subaru and cheaper than the 2017+ version. Here’s the picture side by side. If I could go back I’d get just the 2017+ version. Reason being that it has a longer flat section and earlier in the travel which lets the door stay open at smaller angles (when someone parks really close to you) with the 2022 version the door only stay open in the deeper groove sections (but will definitely stay there) so the door has to open a lot before it can stay open. Not sure if this makes sense.
So it still comes right back at your shins if you just open the door just slightly. I can't believe I'm writing a review for door checkers
FrickingReallySlow is offline   Reply With Quote
The Following 7 Users Say Thank You to FrickingReallySlow For This Useful Post:
Compelica (05-19-2022), ermax (05-18-2022), Jdmjunkie (05-18-2022), Prodigalson (09-03-2024), Tcoat (05-18-2022), Ultramaroon (05-18-2022), WNDSRFR (05-19-2022)
Old 05-18-2022, 03:33 PM   #129
The thing is that this has been a complaint since day one so your review is actually valuable to many.
Also why I felt remorse for not noticing it didn't do it with the new parts so I could pass it on two years ago.
Dadhawk (06-02-2022)
Old 05-18-2022, 07:23 PM   #130
ermax
ermax's Avatar
Yeah I’ve noticed the same thing. It opens a little, a little more and then a lot. I’m in Florida so the first notch seems to hold just fine.
I took some pictures of the door at the three stages.
The Following User Says Thank You to ermax For This Useful Post:
Old 05-18-2022, 07:54 PM   #131
I've come to expect that. sigh
ermax (05-18-2022)
Old 05-18-2022, 07:59 PM   #132
Old 05-18-2022, 08:48 PM   #133
Old 05-19-2022, 10:12 AM   #134
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Can anyone post the part numbers for the 2017 & 2022 versions?
alex87f is offline   Reply With Quote
Old 05-19-2022, 11:38 AM   #135
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
2017 part number is 61124CA001, online for about $33
2022 part number is 61124CC000, online for about $24
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
blsfrs (05-20-2022)
Old 05-19-2022, 12:40 PM   #136
WNDSRFR
Drives: FR-S,GTI
It's great that Toyobaru recognized the problem and solved it. And thirty three bucks is well worth it to fix the only real problem with 86 (besides the TOB of course).
But I think the improved part should be free.
Even though I'm ordering mine today. The original fix on mine is less effective after 200,000 miles.
Old 05-19-2022, 03:26 PM   #137
nextcar
Fact: according to the parts interchange catalog I looked at, the same door stay is used on the front door of ALL modern Subaru vehicles.
Assertion: Owning a Outback too (although a 2019 with the new door stay) I cannot imagine what it must have been like for the earlier Subarus with doors even heavier than the twins... This improvement was doubtless to address the problem on their mainstay vehicles, and was just an unexpected bonus for the twins.
Pull out
Ultramaroon (05-19-2022)
Old 05-20-2022, 03:39 AM   #138
ermax
ermax's Avatar
I think the real issue is they took the check from a sedan and threw it on a coupe with significantly longer doors. Even if the BRZ door is lighter, the mechanical advantage will over work a check designed for a short door. The Twins are a mix of parts from Subaru and Toyota and the checks should have come from Toyota who have several coupes to pull from.
Tcoat (05-20-2022)
Old 05-20-2022, 08:06 AM   #139
This^ All day this.
Not the first time I have run into this issue with a coupe where they just tried to parts bin a door check.
In this case it obviously didn't work well even on the sedans and SUVs so the issue would be magnified on the Twins.
Old 05-20-2022, 01:20 PM   #140
Better check yourself before you wreck yourself
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 06:07 PM
Door open light rosol16 Issues | Warranty | Recalls / TSB 6 11-22-2015 01:42 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-12-2013 12:43 AM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 11:20 AM
