#15 |
Rust bucket enthusiast
Does this seem exclusive to hot starts, or does it affect cold starting, too?
The scaling on the wideband could be goofy, but Delicious should be able to figure that out..
#16 |
Drives: 2014 Toyota FRS
I have several logs where a tuner attempted to fix the issue but was unsuccessful.
https://datazap.me/u/celigts Here’s a log of idle so you don’t have to sift through the logs/tests. https://datazap.me/u/celigts/1351-tune?log=0&data=16 |
#17 | |
Problem isn’t exclusive to cold starts but does seem to be worse in hot weather. Likes to stall more. |
#18 | |
Could be totally unrelated, but there is a intake air temperature compensation fueling map I had to raise to like 150 across the board to let my car to idle correctly on hot starts and in general. My car was stalling on clutch in and generally any time the car wasn't dead cold. This does not sound related, but it could be another contributor.
#19 |
Drives: brz 2017 hksv2
The logs in your datazap account are a pain to watch, should be renominated in Atrocious Tuning
#20 |
#21 |
Ok sorry i ve miss understood, that you were tuned by delicious
if someone is scaling your fueling on your tune and those are logs of that, he s not doing a great good |
#22 |
Drives: Toyota 86
I've experienced similar symptoms when some kind of harness or connector issues related the MAF sensor. After I arranged the harness near the MAF connector it came back normal usually. You should make sure MAF scaling was done with normal connection state.
#23 |
Drives: Toyota 86
And care must be taken when scaling below 1.21V range of MAF sensor.
#24 |
#25 | |
Professional wrench
Drives: 2020 BRZ ST RS
you can monitor your short term fuel trim while you do various things such as idle, stead 2500 rpm in gear, gentle cruise at 2500, decel in gear, accell in gear etc to further isolate where the problem is happening. Rich is both trickier to find and easier to find than lean as only a few mechanical things can cause it. Fuel pump, fuel pressure regulator, kinked return line(tho I suspect this is a returnless system), leaking injector(s), etc. Yes a bad MAF and/or primary O2 sensor can cause this too, as can a bad PCM, but these are where to start
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
#26 | |
P0137 P2096 P219A I’m told these are from the catless header and should be the issue. Getting tuned in person on Monday by Counterspace Garage so we’ll see. Was thinking leaky injectors but I replaced the port injectors. The DI injectors we’re going to be done but I was told it more than likely is a waste of time. 🤔 |
#27 |
Drives: 2023 GR86 M/T
Any updates?
#28 |
Okay so giant horrible news.
A leakdown/compression test was performed. Discovered that it’s leaking in cylinder 3 causing misfires. Compression test failed in cylinder 2 and 3. Engine is apart now at Toyota. Not sure what the cause is but the issue is cylinder 3 is not sealing when it’s at the top of its motion and it’s leaking fluid is what I’m told. Car has 131k miles on it and along with some other maintenance related things (timing chain:tensioner:guides) the car needs a new block I’m told. Any chance I can get Toyota to fork up some of the bill? Am I SOL? Looking like $6500 in repairs on a motor that runs and seemingly runs fine after idle. Able to drive it for seemingly years as I’ve been trying to track down my issue for these few years. Any options? Suggestions? Thanks! |
| Misfires, rough idle, stalling | Cobiflex | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 10-20-2021 04:12 PM |
| RPM dip, stalling on idle | Cebal | Issues | Warranty | Recalls / TSB | 13 | 02-03-2021 12:02 AM |
| pcv delete, surging idle, stalling. | solidsnake11 | Software Tuning | 0 | 10-02-2020 12:01 AM |
| Stalling at idle after startup (see logs) | Eazy-V | Software Tuning | 18 | 04-15-2018 08:33 PM |
| OFT Stage 2 UEL Help. Rough Idle Stalling | shellslinger | Software Tuning | 11 | 03-05-2017 10:33 AM |
