Old 05-13-2022, 10:18 PM   #15
Jynx
Drives: 2013 Subaru BRZ
i haven't tried that, i didn't even know that existed lol. how do u do that? is there a guide or do u literally just unplug the battery completely and step on the brake a few times? no voltage has always stay steady at 12.9 which i know is a little high.
Jynx is offline   Reply With Quote
The Following User Says Thank You to Jynx For This Useful Post:
Ultramaroon (05-13-2022)
Old 05-13-2022, 10:23 PM   #16
Jynx
It is weird. Have you tried rebooting (or whatever it's called) the ECU by disconnecting the battery and stepping on the brake for a couple seconds? Did your battery voltage drop just before it started happening?
if you mean just unplugging the battery yes, i have to anyways to get rid of the engine light/limp mode but i dont get what u mean by the brake.
Old 05-13-2022, 10:37 PM   #17
Oh, gotcha. The brake press is just to make sure the power supply is completely drained. It's a thing.
I just looked at the wiring diagram and I see that the only way for the purge valve to be stuck open is for a short in the wire between it and the ecu, the ecu to be telling it to open for some reason, or for that control transistor (mosfet, whatever) to be shorted.
Old 05-13-2022, 10:53 PM   #18
Jynx
but see i would not know where to even start and the fact that i also get u0155 for using my cruise control makes me wonder just wonder if maybe the ecu is fucked/trashed. im not the original owner but i dont think it has been tuned or anything like that.
Old 05-13-2022, 10:56 PM   #19
It's possible. I wouldn't start with that unless I had money to blow. Even then, I think there's a whole thing to pairing the ecu to the car. Are you up for that?
Old 05-13-2022, 11:03 PM   #20
Jynx
not really but i just want to know what it is and where to honestly start ya know
Old 05-13-2022, 11:09 PM   #21
Jynx
do u think if there wasn't enough pressure in the lines that the ecu would keep the valve open until there was and then it would tell it to close? i wonder if there isn't enough and the computer doesn't like that and it tries to keep it open. is that possible or is that a dumb thought?
Old 05-13-2022, 11:52 PM   #22
It's a good thought, but the service manual does say something about a time threshold for the the evap leakdown test. Read up on it and you'll know as much as I do about the logic. I would think it times out and gives up
Old 05-13-2022, 11:57 PM   #23
Jynx
so it wouldn't be possible or would it and it's just timing out? ive had a lot of people say it could be the gas pump rubber seal
Old 05-14-2022, 01:55 AM   #24
That's the first thing to rule out. I think you know what needs to happen. Just have to start testing.
Old 05-14-2022, 01:29 PM   #25
Jynx
is there a fuel tank pressure sensor in this car?
Old 05-14-2022, 02:59 PM   #26
There's a link to the service manuals in my sig line.
Old 09-18-2022, 06:47 PM   #27
Jynx
yes. i also had a shop smoke test it for leaks and nothing was leaking. only thing that was weird was when they hooked it up to obd2 reader the shop got a christmas tree so maybe ecu issue?
Old 09-18-2022, 06:48 PM   #28
Jynx
Originally Posted by blsfrs View Post
Are you absolutely sure that you don't have a vacuum leak?
100% it has been smoked tested.
blsfrs (09-18-2022)
Help diagnosing P0441 code 1Saucyyy_brz Issues | Warranty | Recalls / TSB 3 09-18-2022 06:45 PM
Engine code p0171 and p0441 frscory Issues | Warranty | Recalls / TSB 6 02-20-2022 07:06 PM
Having trouble with code p0441 Jynx Issues | Warranty | Recalls / TSB 5 02-19-2022 06:17 PM
p0441 cel code bryan.catano93 Engine, Exhaust, Transmission 5 03-12-2018 12:38 PM
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 06:39 PM
