Drives: 2013 Subaru BRZ
Code p0441
hey guys, i have had this code for awhile and this last weekend i changed the purge solenoid, gas cap and checked my lines and after driving it again for a little bit, same code. P0441. Im actually lost on what else to do with it. Maybe an electrical short? im not sure but this weekend im gonna check all my lines again and spray water on them to see if maybe one is cracked but im pretty sure those are all good. Does anyone have any suggestions on what else it could be? car is not tuned, completely stock engine and stock ECU. any ideas/help would be much appreciated. Thanks again.
2013 BRZ Jynx |
#2 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
#3 |
#4 |
Drives: 2020 GMC Canyon Denali Diesel
Couple of questions:
Is the car modified? Are you the original owner? This is definitely an Evap system code, if you answered "Yes" to either of the questions above check the ECM wiring first. ECM is located behind the glove box against the passenger side A pillar. Look for loose wires in the ECM harness. I've seen previously modified cars that had taps into the harness connectors that were either shorted out, or loose that caused this code. If the ECM wiring is fine check the following components as each can cause the code: • Purge VSV (This is located under the intake manifold on the driver's side, it is blue & black, make sure the connector is plugged in securely and the wires are good, check that both purge lines are connected securely. • Purge lines (These are the lines connected to the VSV, make sure they are connected securely on both ends and have no leaks or cuts). • Connector/Wiring harness (Purge VSV - ECM) (As mentioned previously, check these harnesses & connections) • Leakage from the EVAP system (may need to have this taken to a shop to perform a smoke test on the EVAP system to make sure there are no leaks.) • ECM Issue (worst case, needs an ECM)
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following 2 Users Say Thank You to Opie For This Useful Post: | humfrz (05-11-2022), Ultramaroon (05-11-2022) |
#5 |
Drives: 2013 Rally Blue BRZ
#6 | |
just a widebody kit and slammed. no engine mods and I'm not so it kinda sucks but i had another mechanic look at it and the computer is still saying it won't close, its just stuck open which i don't understand. there is a brand new purge valve in there and it's still getting stuck. i tried looking for shorts and i didn't see anything so I'm completely lost at this point. I'll look at the ECM and see if anything is lose. thanks for the help ![]() Sent from my iPhone using Tapatalk |
#7 | |
just checked ECM. nothing is hanging off it or unplugged etc. looks all normal and definitely has never been touched. Sent from my iPhone using Tapatalk |
#8 |
Drives: 2013 frs base
Are you absolutely sure that you don't have a vacuum leak?
#9 |
people don't even bother to look because they watch the purge valve on the computer and say its not closing. its just constantly open so they don't bother which absolutely pisses me off because they think I'm an idiot and I'm not. if i had the damn tools id do it myself Sent from my iPhone using Tapatalk |
#10 |
Can you bench test the purge valve by blowing (or sucking if you're feeling kinky) through it with and then with out current applied to the terminals? Being an electronics noob, I don't know how the car's ecm "knows" whether the valve is open or closed. Does it assume it's open when current is applied or does it monitor changes in vacuum.
#11 | |
i did that with new and old one. both where closed with no power and open with power. ECM could be fucked but it's stock. i also get a u0155 code if i use cruise control so maybe a bad ecu? im not really sure Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Jynx For This Useful Post: | blsfrs (05-14-2022) |
#12 |
Do you have anything plugged into the obd2 port? Gotta ask.
Also, being slammed, unless you have bags, you're shaking the piss out of everything way more than stock. Might be onto something with the connector/short thing. Maybe.
#13 |
#14 |
It is weird. Have you tried rebooting (or whatever it's called) the ECU by disconnecting the battery and stepping on the brake for a couple seconds? Did your battery voltage drop just before it started happening?
| Help diagnosing P0441 code | 1Saucyyy_brz | Issues | Warranty | Recalls / TSB | 3 | 09-18-2022 06:45 PM |
| Engine code p0171 and p0441 | frscory | Issues | Warranty | Recalls / TSB | 6 | 02-20-2022 07:06 PM |
| Having trouble with code p0441 | Jynx | Issues | Warranty | Recalls / TSB | 5 | 02-19-2022 06:17 PM |
| p0441 cel code | bryan.catano93 | Engine, Exhaust, Transmission | 5 | 03-12-2018 12:38 PM |
| Check engine code P0441 | Gibson | Engine, Exhaust, Transmission | 0 | 11-23-2016 06:39 PM |
