Drives: 16FRS hks SC 10:1 91 ecutek
Bad cold start 10:1 91
i got a forged shortblock IAG stage 2 10:1 CR
with a hks v3 SC and some supertech valve springs Since then my cold starts have been horrible my tuner is taking forever to get back to me so now im giving the forum a tryfuel trims are +9ish until it goes to PI then it drops to +3ish AFR are good 14.6 it jumps around a lil my ignition timing is at -4.9 when its bad then when it figures itself out it will jump up to +13 - +14 ive also noticed when it does figure itself out the oil temp is at 100F i have checked my vacuum lines under the manifold, pcv , and the one that goes to the solenoid any input is appreciated |
#2 |
Hey you may want to try this in the technical section, you are in the classifieds right now.
#3 |
Drives: hyper blue
the prez version of subaru has a larger cat AND has a hellish timing retard on start up.
see if you coolant temperature sensor for the ecu is putting out the correct value. |
| Tags |
| bad fuel trims, cold starts |
| Cold cold(under 30dg) start sounds super weird | vladniko86 | Engine, Exhaust, Transmission | 9 | 11-19-2020 10:08 PM |
| Cold start pop | Ash3482 | Engine, Exhaust, Transmission | 3 | 03-07-2019 08:39 PM |
| Cold Start Help | Kayysonie | Software Tuning | 39 | 04-01-2016 12:35 AM |
| Cold start | JG | Engine, Exhaust, Transmission | 8 | 08-29-2015 03:55 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
