Old 04-14-2022, 04:26 PM   #1
daniloneil8
Is there any value in an OEM taillight with cracked outer clear lens?
Works but just the clear outer lens is smashed.
daniloneil8 is offline   Reply With Quote
Old 04-14-2022, 04:50 PM   #2
Hold onto it. Will likely become collectible in a few years.
SuperTom (04-18-2022)
Old 04-14-2022, 05:05 PM   #3
daniloneil8
Can they be repaired? If I can replace the outer lens, I will do it and save it for the next guy that gets rear ended.
The Following User Says Thank You to daniloneil8 For This Useful Post:
Ultramaroon (04-14-2022)
Old 04-14-2022, 05:21 PM   #4
Unfortunately, no. It's toast.
Old 04-14-2022, 07:21 PM   #5
daniloneil8
But, I've read that people bake off the lens and replace it ?
Old 04-14-2022, 07:38 PM   #6
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
yes you can do that but good luck with ensuring a water tight seal. look up the many threads on here where folks have reported moisture inside the lens after opening their headlights/tailights.
HKz is offline   Reply With Quote
Old 04-14-2022, 07:55 PM   #7
It is far more trouble than it is worth.
Grady (04-18-2022)
Old 04-14-2022, 07:57 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
most tail lights are sonically welded/glued. so they must be cut apart.
the parts you're reading are in reference to headlamps that typically use butyl rubber as a sealant that can be softened with heat and can be easily opened.
the shorter answer is that there's really no benefit to replacing the lens. lenses aren't sold separate from housings, so one must buy a complete replacement housing anyways. and there's nothing custom/unique/different about the oem tails that justifies the double expense or the labor for the work.
Old 04-18-2022, 01:55 PM   #9
daniloneil8
Ok, I will remove the 2 bulbs and toss the housing.
Tcoat (04-18-2022)
Old 04-18-2022, 06:13 PM   #10
charlesdominguez877
Drives: Corolla Mazda
Hello
Sent from my iPhone using Tapatalk Pro
charlesdominguez877 is offline   Reply With Quote
Old 04-18-2022, 09:18 PM   #11
soundman98
soundman98's Avatar
goodbye
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Tcoat (04-19-2022), Ultramaroon (04-19-2022)
Old 04-19-2022, 01:55 PM   #12
Hello
Hello, hello
I don't know why you say goodbye
I say hello
soundman98 (04-19-2022)
Old 04-19-2022, 02:28 PM   #13
Hello
Hello, hello
I say hello
You say yes
I say no
You say stop and I say go, go, go
Valenti CR-2 Clear lens with chrome inner housing Vinhooo Exterior Parts (Aero, Lighting, Etc.) 4 04-23-2021 04:45 PM
WTB: looking for preferably clear lens v1 tom taillights snpie Want-To-Buy Requests 2 04-20-2020 11:46 AM
*LEGIT USDM TOM'S TAILS US LEGAL! RED LENS & CLEAR LENS $450 AUTHORIZED DEALER!!!* Vicious LED Exterior Parts - Lighting 121 04-19-2014 05:13 PM
TOM'S clear LENS tail lights, Black / RED SliverBrz Cosmetic Modification (Interior/Exterior/Lighting) 16 08-19-2013 05:56 PM
Cracked taillight Drftfan Issues | Warranty | Recalls / TSB 2 07-12-2013 07:58 PM
