Drives: 2018 BRZ
Track Pad Swap Question
I will be using a track specific pad for the track and a street pad for daily use. When I remove the track pads is it important to be sure they go back in the same position (drivers vs. passenger side/inside vs. outside of caliper) when reinstalling for the next track event? I assume it does not matter, but would rather be sure.
#2 |
Related question - is there a specific bedding in process to follow when switching pads?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
#3 |
Yes you should try to label them so you know which caliper and position inner or outer but its not 100% required.
Try to stick with the same compound for street and Track. Example I use Carbotech 1521's for street driving (100% quiet) and switch XP10's/8's for track driving and never need to re-bed. But if they are different manufactures or pad materials you will/want to bed the pads in each time or risk not getting optimal brake feel/stopping power
2013 Series 10 FRS #553
#4 |
Thanks, sounds like just normal bedding, not some tricky cleaning process prior to swapping the pads. Just need an extra day or so rather than switching at the event.
#5 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | andys_garage (05-13-2022) |
#6 |
Drives: 14FRS
planning on doing the same, what can I swap to if I'm using stock brake pads (first gen frs)?
#7 | |
Drives: 2012 BRZ Premium WRB 6MT
We did a couple videos on this topic...hopefully these help. These methods will work on any pads and discs once you understand the underlying concepts.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
| The Following User Says Thank You to JRitt For This Useful Post: | andys_garage (05-13-2022) |
| Question on a WRX FA20 swap into a FRS | Stoll_It317 | Engine Swaps | 6 | 07-27-2017 05:33 PM |
| WK V3 - Spring Swap Question | Stang70Fastback | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-18-2016 08:29 PM |
| LSx engine swap for track use, thread | foodman | Tracking / Autocross / HPDE / Drifting | 77 | 03-16-2015 03:23 PM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 01:08 PM |
| Headlight Swap Question | nogaroblues4 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-07-2012 02:45 AM |
