Old 03-01-2022, 02:07 PM   #1
86runner
Drives: Silver FRS
Clutch or transmission problem?
Getting shift lockout in first and reverse when going from a stop, been happening since I had a new clutch put in.
86runner is offline   Reply With Quote
The Following User Says Thank You to 86runner For This Useful Post:
humfrz (03-01-2022)
Old 03-01-2022, 04:15 PM   #2
Not getting full disengagement. Take it back and make them fix it before you kill the balk rings in your syncros.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
humfrz (03-01-2022), norcalpb (03-01-2022), RedReplicant (03-01-2022), x808drifter (03-02-2022)
Old 03-01-2022, 09:27 PM   #3
Welcome to our forum -
I suggest someone bleed and adjust the clutch.
Old 03-01-2022, 09:56 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
What clutch did you have installed? its not an ACT by any chance?
1974 TA22 Celica
2013 86 GT
Old 03-07-2022, 07:47 PM   #5
zberz
Drives: 2015 Lightning Red BRZ
Curious which clutch you have. I have an ACT that started doing this. I've been living with it for a while but intend to replace soon.
Sent from my SM-G950U using Tapatalk
zberz is offline   Reply With Quote
Old 03-07-2022, 10:33 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
There are quite a few threads around about ACT clutches dragging and making engaging first difficult.
I'd strongly recommend exedy clutches as they make the OEM unit for Toyota and Subaru.
1974 TA22 Celica
2013 86 GT
Old 03-22-2022, 10:43 PM   #7
stillslow93
Drives: 2015 BRZ JDL Turbo
I just made a post about this. I have an ACT that was acting up and the culprit was bad install (I had a shop do it TWICE)
I finally did it myself last fall and have been smooth sailing ever since
stillslow93 is offline   Reply With Quote
Old 03-23-2022, 09:53 AM   #8
Grady
Grady's Avatar
Please tell us more. How the hell do you F up a clutch install?
Old 03-23-2022, 03:29 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
I'm still driving stock clutch and i have not boosted mine or drift it, to require uprated clutch install .. but this topic interests me too. As seen too often "ACT slips, get X instead". I'm guessing, that maybe something in their install instructions is fscked up for such (relatively) frequent misinstalls? But wondering, what .. (if for nothing else, at least to point to shop to pay extra attention and double check with)
Wally86 (03-29-2022)
Old 03-23-2022, 03:41 PM   #10
pope
has a funny hat
Drives: 2014 BRZ Limited
and unfortunately his “solution” includes no details about finding anything done incorrectly and even states he doesn’t know what the shop or anyone else did (or does) wrong.
My guesses are better lubrication, millimeters of tighter hydraulic actuator positioning for a hairs worth more release, the disc burnt down just enough to release, or dumb luck.
pope is offline   Reply With Quote
Old 03-27-2022, 07:46 PM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Maybe the new clutch lowered the clutch engagement point closure to the firewall. Maybe adjust the clutch pedal height to make sure you have enough foot travel to fully disengage the clutch from the flywheel.
Old 04-06-2022, 05:40 PM   #12
stillslow93
Well I would love to know to because they did it twice and tried to tell me that something was wrong with my transmission because of my problems (which it most certainly was not the culprit)
I can tell you that I used the metal alignment tool from OS Giken after hearing that the plastic tool shipped with ACT is garbage. I also made sure to grease everything from the fork to the TOB and took my time tightening everything to spec and checking everything twice.
I haven't had any issues since I did the install, but BOTH times after the shop put the clutch on it started acting up about 500 miles in. Seriously, no clue what they were doing but it was a reputable shop in the area who specializes in Evos/WRX/Etc
Old 04-09-2022, 01:33 AM   #13
Irace86.2.0
When you changed your clutch, what did you see that was wrong with it? I’m assuming you slid the OS Giken tool in position to see how misaligned things were before disassembling the clutch assembly to realign it?
I’ve done multiple installs of the clutch assembly and transmission with home made alignment tools to plastic tools. Ive never had a problem with lockout or aligning things. It is surprising that a shop failed twice.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zc06_kisstherain (04-12-2022)
Old 04-12-2022, 08:34 PM   #14
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I agree it's good that he fixed it but...
Yet Another Transmission Problem zberz Engine, Exhaust, Transmission 11 07-13-2021 11:39 PM
2015 BRZ Transmission problem.. SamtheKorean Issues | Warranty | Recalls / TSB 13 09-13-2018 10:47 PM
Transmission Problem frosty86 Issues | Warranty | Recalls / TSB 36 10-21-2015 10:17 AM
Transmission Problem! johnnylai Issues | Warranty | Recalls / TSB 6 02-07-2014 03:54 PM
