#855 |
TRACKBREAD
Debadging is so easy when the car is new too. I’ve always done it on a 4-7 year old car and the dried out adhesive always puts up a fight, and then the area needs paint correction so you no longer see the ghost letters compared to the wear around them. This time the adhesive just came off with gentle peeling, and all I needed was to apply some wax on the area when I was done.
#856 | |
- Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#857 | |
Drives: '23 BRZ Limited
I always used my heat gun and a bit of dental floss. Done. |
#858 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
#859 |
Drives: '22 BRZ
Hmm maybe I should debadge mine too
#860 | |
What was your alignment and how was the car’s balance?
2022 BRZ Build 2013 FR-S Build |
#861 | |
Drives: Ford Fiesta ST, 2022 Subaru BRZ
My camber is at -2 at the front. Not wildly aggressive, but it's kind of a decent balance between street and track at the moment. The car's balance felt really good, very easy to place the car where I wanted it and the chassis felt super communicative. I'm still picking up some understeer on certain corners. But before I go down the path of changing more suspension components, I'm going to just try a wider, stickier tire to see if it helps. The Pilot Sport 4's are surprisingly pretty good but I am greatly missing the grip that comes with a good set of 200TW tires. |
| The Following User Says Thank You to Rcode For This Useful Post: | DarkSunrise (04-13-2022) |
#862 |
Drives: 2022 BRZ
First oil change. Now i just need to do a thorough post-Winter cleaning.
#863 |
Drives: '22 BRZ
Installed the Toyota OEM mudflaps. Not quite as much protection from the front flaps as I'd like, but that's OK.
#864 |
Drives: 2022 Subaru BRZ 6MT IR
I'd like something between the two different OEM options. My Subaru front flap is so long that it hits the ground over every big bump and even under hard cornering. Its flexible, but even still its permanently bent backwards now from all the impacts.
2022 BRZed, Red, Base, Manual, Simple
| The Following User Says Thank You to 22 BRZ For This Useful Post: | DocWalt (04-14-2022) |
#865 |
Drives: 2015 Scion FRS Release Series 1.0
You got TSVs!! I have them in order-what size is that?
#866 | |
Drives: '22 BRZ
yeah I'd love something more like the first gen Subaru mudflaps, molded but sleeker and still kinda flexible. 17x9 ET45, 10mm spacer up front. I love them! They look fantastic, even if they're not the lightest wheel ever.
#867 | |
Drives: '22 BRZ
So if I decide to lower in the car in the future its going to be permanently touching the ground. I don't think I'll be doing that cause its my daily in the winter but definately something for others to consider |
#868 |
Nice. I ordered 18x8.5 +40s, will be interesting to see how those look.
| WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 11:36 PM |
| Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 03:51 PM |
| just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 11:05 PM |
| TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 02:16 AM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
